unitra
Conectat la: 17 Aug 2007 Mesaje: 89 Locatie: Arad
Trimis: Vin Mai 30, 2008 12:22 pm Titlul subiectului: Vand DENON AVR-3805, NAD 325BEE, Kit Bookshelf Vifa |
DENON AVR-3805 stare foarte buna, carte tehnica, microfon,telecomanda
7x120W
2000ron pret fix
informatii - unitra8@yahoo.com sau pm
NAD 325BEE ca nou, stare perfecta atat estetic cat si functional.
995 RON
Kit Bookshelf Vifa NOU , 400ron
Kit-ul contine:
- 2x D25AG77-06
- 2x TC14WG49-08
- 2x crossover (filtre)
- schema cutie
- schema filtre
- parametrii difuzoare
This 2-Way kit offers a premium, yet incredibly affordable system using Vifa drivers and custom crossovers. Both the woofer and tweeter were produced in Denmark, and the crossovers are fully assembled for easy hook up and installation.
The tweeter is the 1” Aluminum Dome D25AG77-06. It is a sleek black dome version of an all time favorite; the D25AG05-06. The mid/bass woofer is the 5.5” Treated Paper Cone TC14WG49-08. Both units are technically solid, model very well, and most importantly sound great together.
We took great care ensuring that this kit not only provides high end drivers, but also has a crossover to match. The drivers proved very agreeable, resulting in a relatively simple crossover network with a smooth phase response. The tweeter circuit is 2nd order (12db/octave) with fixed L-Pad for attenuation. The woofer circuit is 1st order (6db/octave) with an impedance compensation network. The crossover point is 3kHz. Our measured results verify a flat frequency response, which you can view below. Overall performance through listening tests is excellent. The presentation is nicely balanced and exactly what we have come to enjoy from Vifa systems.
set 4 difuzoare beyma 8BR40 16ohmi
Vand set 4 difuzoare Beyma 8BR40 16ohmi, aproape noi, stare perfecta de functionare, fabricate in Spania, pret per set. 390RON
tweeter Jamo, se vand doar pereche, pret per pereche (NOI) 70ron
Well-engineered tweeter featuring a textile dome, large semi-horn loaded plastic faceplate, ferrofluid cooling, and magnetic shielding. The faceplate is beveled, minimizing the need to flush mount the tweeter. A damped cavity behind the dome lowers the driver's resonance frequency. Made by Philips for JAMO. Manufacturer buyout, limited quantities. Specifications: *Power handling: 40 watts RMS/80 watts max VCdia: 1" *Impedance: 4 ohms *Re: 3.46 ohms *Frequency response: 1,000-19,000 Hz *Fs: 1,200 Hz *SPL: 86 dB 1W/1m *Dimensions: A: 4-3/8", B: 3-3/8", 1-1/2".
* Textile dome with aluminum VC former
* Smooth response and usefully low Fs
* Semi-horn loaded faceplate
* Ferrofluid-cooled voice coil
* Magnetically shielded
* Made by Philips for JAMO
Ultima modificare efectuata unitra la Sam Mar 26, 2011 3:02 pm, modificat de 17 ori in total |
Trimis: Vin Mai 30, 2008 12:22 pm Titlul subiectului: Mitica |
25.44 KB |
176 Time(s) |
123.56 KB |
175 Time(s) |
295.03 KB |
415 Time(s) |
unitra
Trimis: Vin Iun 06, 2008 1:04 pm Titlul subiectului: |
Up!
oake
Conectat la: 28 Iun 2005 Mesaje: 606 Locatie: Bucuresti
Trimis: Lun Iun 09, 2008 6:03 pm Titlul subiectului: |
unitra tu ai facut cutiile...sunt f bine lucrate...ma gindesc ca putem colabora in sensul asta.
_________________ Mielul blind suge la oaia neagra a familiei |
unitra
Trimis: Sam Iun 14, 2008 11:30 pm Titlul subiectului: |
up!
Ultima modificare efectuata de catre unitra la Sam Apr 23, 2011 12:34 pm, modificat de 1 data in total |
unitra
Trimis: Vin Iun 20, 2008 10:57 pm Titlul subiectului: |
Up!
cristi@n
Conectat la: 19 Ian 2008 Mesaje: 16 Locatie: Resita
Trimis: Mar Iun 24, 2008 5:49 pm Titlul subiectului: |
Pot sa intreb de ce le vinzi ? Nu iti place cum suna sau de ce. Intreb asta pt. ca as dorii sa imi construiesc si eu niste vtp-uri cu aceste difuzoare.
Mersi
unitra
Trimis: Vin Iun 27, 2008 11:09 pm Titlul subiectului: |
Up!
unitra
Trimis: Mar Iul 08, 2008 9:41 pm Titlul subiectului: |
Vandute.
unitra
Trimis: Mie Noi 05, 2008 10:22 pm Titlul subiectului: |
vandut.
39.57 KB |
998 Time(s) |
Ultima modificare efectuata unitra la Mie Mai 26, 2010 5:05 pm, modificat de 3 ori in total |
nicumur Vizitator
Trimis: Joi Noi 06, 2008 9:43 am Titlul subiectului: |
Threaduri comasate si blocate 30 de zile
nicumur Vizitator
Trimis: Lun Dec 08, 2008 12:40 pm Titlul subiectului: |
up@go!
unitra
Trimis: Joi Dec 18, 2008 2:01 am Titlul subiectului: |
up!
mariusmaita
Conectat la: 18 Dec 2008 Mesaje: 5 Locatie: BUFTEA
Trimis: Joi Dec 18, 2008 8:10 pm Titlul subiectului: |
salut.vreau si eu poze cu zgarieturile alea.merci.sal.
unitra
Trimis: Vin Ian 16, 2009 6:44 pm Titlul subiectului: |
pentru poze mai detailate apelati-ma pe PM, nu stiu sa pun poze asa mari
unitra
Trimis: Dum Apr 05, 2009 11:16 pm Titlul subiectului: |
