PolyGram
Conectat la: 24 Iun 2006 Mesaje: 1639 Locatie: viseu de sus(sus de tot, in mm)
Trimis: Mar Feb 03, 2009 3:38 pm Titlul subiectului: DBS |
...daca tot exista un subiect despre cablurile Kimber in care sunt laudate cablurile AudioQuest, de ce sa nu fim corecti si sa deschidem un subiect despre cablurile AQ in care sa fie laudate cablurile Kimber
Lasand gluma la o parte, pentru ca mi-au trecut prin mana cabluri AQ, cabluri bune dealtfel, avand calitati de necontestat, sunt sincer interesat de aceasta tehnologie aleasa pentru unele cabluri de la AQ, adica DBS cu..."x" volti, mai multi sau mai putini. De fapt exista doar cateva variante, adica un anumit nr. de volti.
Care este teoria din spatele acestui DBS? Care sunt beneficiile, avantajele? _________________ Ignoranta poate fi o explicatie, dar nu o scuza. |
Trimis: Mar Feb 03, 2009 3:38 pm Titlul subiectului: Mitica |
AWDRobert
Conectat la: 23 Mai 2008 Mesaje: 139 Locatie: Otopeni
Trimis: Mar Feb 03, 2009 5:07 pm Titlul subiectului: |
DBS? mai degraba BS _________________ Robert
Sa auzim numai bine |
fojica
Trimis: Mar Feb 03, 2009 6:11 pm Titlul subiectului: |
cred ca asta ar fi teoria din spate:
**AudioQuest argues that the phenomenon of cable break-in is actually a matter of the dielectric adapting to a charged state, and whenever the cable is not being used, it returns to its uncharged state. The DBS consists of an insulated anode and uninsulated cathode inside each cable run that are connected to a pair of 36V battery packs affixed to the cable's downstream end. The battery packs keep the cable's dielectric constantly charged with 72V DC and thereby ensure that the dielectric never drains its energy as distortion, providing "considerably better transparency and dynamics than are possible even from a cable in continuous use."**
se specifica la un moment dat si despre tensiunea bateriilor in cauza:
**AudioQuest has found that 50 volts is the threshold above which the benefits of additional voltage are "pretty subtle," according to Harley. However, the DBS battery packs are 36V each, due to the use of three 23AE 12V batteries. So AudioQuest's higher-end DBS cables come with two battery packs that run in parallel to produce 72V -- a bit of overkill, according to AudioQuest, but "72V DBS does provide a subtle but noticeable improvement over 36V."**
sursa:
http://www.soundstage.com/revequip/audioquest_sky_volcano.htm |
Trimis: Mar Feb 03, 2009 8:04 pm Titlul subiectului: |
Ce e interesant este ca spun ca au pus "pack-urile" de baterii in paralel si au obtinut 72V |
catalinmetal
Trimis: Mie Feb 04, 2009 4:31 pm Titlul subiectului: |
ce nu m-ar mira ca toate cablurile astea "de firma" sa fie comandate la aceeasi firma prin china sau pe-acolo, si doar sa schimbe "invelisul"... si noi sa dam in bobi comparand acelasi cablu dar de alta culoare... si pret.
treaba cu bateriile in paralel este o chestie... ar trebui rescrisa legea lui ohm: " esti om cu mine, sunt om cu tine" (la ei ar fi legea lui Man) |
Bogdan
Trimis: Mie Feb 04, 2009 5:44 pm Titlul subiectului: |
katalin a scris: | Ce e interesant este ca spun ca au pus "pack-urile" de baterii in paralel si au obtinut 72V |
Fals. Sunt conectate in serie.
AWDRobert a scris: | DBS? mai degraba BS |
Pe ce iti bazezi afirmatia ? |
aifaq
Conectat la: 13 Ian 2006 Mesaje: 1074
Trimis: Mie Feb 04, 2009 5:53 pm Titlul subiectului: |
Bogdan a scris: | AWDRobert a scris: | DBS? mai degraba BS |
Pe ce iti bazezi afirmatia ? | Pe traditionala oftica si gheara in git a celui ce nu si le poate permite ?! |
saureign
Conectat la: 07 Noi 2007 Mesaje: 331 Locatie: ...
Trimis: Mie Feb 04, 2009 6:14 pm Titlul subiectului: |
beneficiile ar fi la soundstage si dinamica. Oricum, sistemul DBS este patentat in USA, drept pt care se plateste si inovatia...
Dupa cum am mai spus pe alt topic de aici, am facut proba la acelasi sistem cu DBS / fara DBS, iar lipsa acestuia se simte (in rau). |
AWDRobert
Trimis: Joi Feb 05, 2009 12:05 am Titlul subiectului: |
aifaq a scris: | Bogdan a scris: | AWDRobert a scris: | DBS? mai degraba BS |
Nu stiu cat costa - cablurile mele au costat 150RON perechea (kimber 8pr) _________________ Robert
c6t9
Trimis: Joi Feb 05, 2009 12:19 am Titlul subiectului: |
de fapt despre ce cablu vorbim?
din ce am vazut, folosite des sunt cablurile pt boxe. _________________ nu am nici o putere. fie ce-o fi.
cata... |
c6t9
Trimis: Joi Feb 05, 2009 12:21 am Titlul subiectului: |
a, am vazut 8pr, deci tot boxe. _________________ nu am nici o putere. fie ce-o fi.
cata... |
AWDRobert
Trimis: Joi Feb 05, 2009 1:56 am Titlul subiectului: |
Brosura Everest: http://www.audioquest.com/pdfs/earth_feature/everest.pdf
Desenul ne arata "conductive dielectric"
Wikipedia - dielectric:
"A dielectric is a nonconducting substance, i.e. an insulator. The term was coined by William Whewell in response to a request from Michael Faraday.[1] Although "dielectric" and "insulator" are generally considered synonymous,... "
Alti termeni tehnici in brosura - ne -la - locul lor - "Positive / Negative conductor group" - adica cablul negru la borna neagra si cablul rosu la borna - ati ghicit rosie. Dar ca sa tina cititorul in suspans mai vorbeste si de anod / catod
Mai zice ca bateriile nu se descarca pentru ca "there is no load" - deci care e treaba - dielectricul e "conductive" sau nu?
Earth feature spiraling - asta imi scapa - pur si simplu firele nu se puteau aranja frumos daca nu erau spiralate straturile in sens opus. Sau e vorba de efectul Coriolis - asta insemna ca cele fabricate pentru emisfera sudica sunt spiralate invers? - eu cred ca asa ar trebui
Da am vazut pe audiogon de vinzare - SH cele "mai slabe" de doar 36V - la 150$ - poate au bateria descarcata.
Sa stiti ca la mine la servici la unele cabluri pe care le instalam nu este recomandata indoirea acestora la raza mai mici decit 10xDiametru (d- intre 22 si 40mm) cablului. Daca o faci degradarea este masurabila / evidenta (VSWR - vezi Wiki). Vorbim de cabluri profesionale care functioneaza pina la 2,5GHz (giga) - atenuare de cca 5db/100m - aici au loc cu adevart fenomene de linie de transmisie si efect pelicular. Din aceasta cauza conductorul central e gros cca 8mm - dar e teava - pentru ca in interior oricum nu ar circula curent - costa 5-10 eur/m.
http://www.commscope.com/andrew/eng/product/trans_line_sys/coaxial/wireless/index.html
Ma mir ca nu sunt astfel de instructiuni privind indoirea pentru aq.
Se mai poate citi si pe http://www.audioholics.com/education/cables/top-ten-signs-an-audio-cable-vendor-is-selling-you-snake-oil/audioquest-responds-to-top-10-snake-oil-article _________________ Robert
saureign
Trimis: Joi Feb 05, 2009 9:44 am Titlul subiectului: |
Daca nu ne pricepem, hai sa tacem. Daca n-am ascultat, hai sa tacem. Daca n-am testat cu sau fara DBS, hai sa tacem.
Restul e frustrare. |
dinica
Conectat la: 07 Sep 2007 Mesaje: 1344 Locatie: Bucuresti
Trimis: Joi Feb 05, 2009 12:08 pm Titlul subiectului: |
AWD, sa inteleg ca brosura de la cablurile AQ este plina de bulshituri? Eu nu ma pricep, din acest motiv te intreb... _________________ dealer audio
When sound becomes music !? |
c6t9
Trimis: Joi Feb 05, 2009 1:39 pm Titlul subiectului: |
problema e daca a nivelul asta isi pot permite sa o dea in balarii sau nu, pt ca de ascultat cred ca suntem si noi capabili, iar daca nu sesizam diferente, cred ca ar fi o prostie sa cumperi doar pt ca cineva iti spune ca sunt acolo. daca chiar si chiar nu auzi ceva, oare are vreun sens sa cumperi un produs? _________________ nu am nici o putere. fie ce-o fi.
cata... |
