REGA DAC sau XINDAK DAC5
Du-te la pagina Anteriorul  1, 2, 3  Urmatorul
Creaza un subiect nou   Raspunde la subiect    Pagina de start a forumului HiFi & Multimedia -> Ce sa cumpar ?
Human
Conectat la: 01 Noi 2003
MesajTrimis: Mar Dec 21, 2010 5:48 pm    Titlul subiectului: Raspunde cu citat (quote)
mai ai varianta Audio Nemesis undeva tot pe la 500 euro.
http://www.tnt-audio.com/sorgenti/anemesisdc1_1_e.html
http://www.audionemesis.com
MesajTrimis: Mar Dec 21, 2010 5:48 pm    Titlul subiectului: Mitica
catalin_bm
Conectat la: 18 Ian 2007
MesajTrimis: Mar Dec 21, 2010 7:25 pm    Titlul subiectului: Raspunde cu citat (quote)
Xindak DAC 5
Analog Devices AD1852 24Bit/192KHz DAC
S/N Ratio : ≥ 114dB
Dynamic Range: ≥ 114 dB
Channel Separation: ≥ 120 dB
Total Harmonic Distorsion: ≤ 0.0016%
Bonus:
Dual output mode is another exciting feature of DAC-5
- Vacuum tube analog output is based on a 6922/ECC88 tube [upgradabil]
- Solid-state analog output is based on Burr-Brown's OPA2064 Op-Amp.
Format 430x110x345 mm deci vine excelent in linie cu celelalte comp.
Rega DAC
DAC Wolfson WM8742
Signal To Noise Ratio -105dB
Total Harmonic Distortion (24bit 96KHz) = 0.006%
USB Isolated (16bit 32/44.1/48KHz)(USB is limited to 16bit)-- nu-mi foloseste
Dimensions in cm W 21.5 x D 27 x H 8
Musical Fidelity M1DAC
24 bit Delta-Sigma (bit stream) dual differential 8x over-sampling to 192kHz
Signal to noise >119dB
Channel separation >105dB
Total harmonic distortion <0.0025%
Cambridge Audio DacMagic - exclus
Arcam rDAC - exclus , prea seamana a router
Deci dupa cum sta treaba, maine am sa-mi comand un Xindac DAC 5
Oricat de mica ne este leafa, noi tot putem munci mai putin decat ne platesc ei.
Alexx
Conectat la: 04 Iul 2007
MesajTrimis: Mar Dec 21, 2010 7:27 pm    Titlul subiectului: Raspunde cu citat (quote)
obuzel a scris:
Pai are importanta la ce calitate trimite semnalul la DAC.
Pai nu trimiti bit perfect pe langa placa de sunet? Vorbesc de semnal prin USB aici.
Conectat la: 08 Feb 2008
MesajTrimis: Mar Dec 21, 2010 8:04 pm    Titlul subiectului: Raspunde cu citat (quote)
Parca Catalinmetal a incercat si a fost incantat de un Xindac DAC5.
Ori santem audiofili, ori nu mai santem.Nu putem asculta toti Schopenhauer.
Liv32
Conectat la: 22 Aug 2009
MesajTrimis: Mar Dec 21, 2010 8:09 pm    Titlul subiectului: Raspunde cu citat (quote)
Eu am luat Lite Dac 60 si pana in acest moment nu am avut nevoie de altceva. Sincer am schimbat lampile originale cu niste Tesla NOS (la acest dac sunetul este legat direct de calitatea lampilor).
catalin_bm
MesajTrimis: Mar Dec 21, 2010 9:42 pm    Titlul subiectului: Raspunde cu citat (quote)
Ceatza densa, incepe invartealla in jurul cozii.
Oare merita un DAC daca am placa asta ?
Asus Essence ST
Output Signal-to-Noise Ratio (A-Weighted):
124dB for Front-out,117dB for Headphone-out (600ohms) dB
Input Signal-to-Noise Ratio (A-Weighted):
118 dB
Output THD+N at 1kHz:
0.0003% (-110dB) for Front-out, 0.001% (-100dB) for Headphone-out
Audio Processor:
ASUS AV100 High-Definition Sound Processor (Max. 192KHz/24bit)
24-bit D-A Converter of Digital Sources:
Texas Instruments PCM1792A*1 for Front-Out (127dB SNR, Max. 192kHz/24bit)
24-bit A-D Converter for Analog Inputs:
Cirrus-Logic CS5381* 1 (120dB SNR, Max. 192kHz/24bit)
High Fidelity Headphone Amplifier:
Texas Instruments 6120A2*1 (120dB SNR, 100dB THD+N @ Vcc±12V, RL=600Ω, f=1kHz)
ttsto
Conectat la: 30 Ian 2007
MesajTrimis: Mar Dec 21, 2010 10:28 pm    Titlul subiectului: Raspunde cu citat (quote)
La mine in sistem, CA DacMagic alimentat prin coax de la M-Audio Audiophile 24/96 a fost net superior iesirii analogice a respectivei placi.
Stereo: Squeezebox Touch, CA DacMagic, HK-990, Kef iQ7
Multicanal: Oppo BDP-83, NAD T765-HD, HK-990, Kef iQ7 + iQ3 + iQ6c + PSW2500
Cabluri: Digital - Chord Signature SPDIF; Analog - Chord Chorus XLR, Chord Chorus MK1; Boxe - Chord Epic Super Twin, QED Silver Anniversary XT
Control: Squeezebox Controller, Logitech Harmony One
Muzica: http://www.last.fm/user/ttsto/library
mihai.balaci
Conectat la: 12 Noi 2010
MesajTrimis: Dum Dec 26, 2010 5:27 pm    Titlul subiectului: Raspunde cu citat (quote)
pentru cei interesati de upgrade aici am gasit lucruri interesante.
mi-a atras atentia CA MagicDAC:
http://www.fidelityaudio.co.uk/cdupgrades.shtml
eu am decis sa incarca sa-mi fac singur un DAC pe baza unui TDA 1541 scos dindtr-un cd philips.
revin cu info daca iese ceva.
ELAC 189 + Yamaha RX-797 + Philips CD-820 TDA1541A Tuned + DAC Philips TDA1541A buffer Lampa
Conectica Klotz 4x4 bi-wired / In-akustik
mihai.balaci
MesajTrimis: Vin Ian 14, 2011 12:33 am    Titlul subiectului: Raspunde cu citat (quote)
revin cu foto:
dacul e gata !!!
am folosit un tda 1543 (intentionez un update la 1541A).
poze
http://img811.imageshack.us/img811/5908/20110108001.jpg
http://img94.imageshack.us/img94/1568/20110108002.jpg
http://img263.imageshack.us/img263/5738/20110108005.jpg
http://img524.imageshack.us/img524/3101/20110108008.jpg
http://img707.imageshack.us/img707/9425/20110108010.jpg
suna bine zic eu...cu precadere pe voce si bass.
mihai.balaci
MesajTrimis: Vin Ian 14, 2011 4:45 pm    Titlul subiectului: Raspunde cu citat (quote)
l-am comparat cu un rockna RD2 aseara.
setup: Anthem 225 + Elac 249
Rezultatele :
- exceleaza la voci, eu cred ca bate rd2-ul.
- bass mai cald, rd2-u parca e putin in fata.
- inalte suna mai bine rd2.
Probabil upgrade-ul la 1541A va mai skimba situatia.Momentan este tot ce ti-ai putea dori la banii investiti.
catalin_bm
MesajTrimis: Dum Ian 16, 2011 10:19 am    Titlul subiectului: Raspunde cu citat (quote)
Pana la urma am cumparat Marantz SA15-S2
Cirrus Logic CS4398 DAC
mihai.balaci
MesajTrimis: Dum Ian 16, 2011 12:02 pm    Titlul subiectului: Raspunde cu citat (quote)
sa-l asculti cu placere listening
catalin_bm
MesajTrimis: Mie Feb 02, 2011 10:41 pm    Titlul subiectului: Raspunde cu citat (quote)
Ce face ZAMBILICA cand nu are ce face ?
- Se scarpina'n cur pana isi face rana.
Desi nu am nevoie, nu ma pot abtine sa nu am un Xindak DAC 5. Asa ca fac un ultim apel la cei care au ascultat acest DrAC, sa dea cu batzul, sa arunce cu pietre in jigodie. Made in china sau labareala made in china ?
Shocked
kurupt
Conectat la: 15 Aug 2003
MesajTrimis: Vin Feb 04, 2011 4:29 pm    Titlul subiectului: Raspunde cu citat (quote)
Pai Xindac este o firma chineza, ar fi tare sa produca in alte tara.
/// Alpine 9855R - Audison LRX 1.400 - Audison LRX 4.5 - U-dimension JR comp - JL Audio 12W7
ttsto
MesajTrimis: Vin Feb 11, 2011 4:17 pm    Titlul subiectului: Raspunde cu citat (quote)
catalin_bm a scris:
Shocked
l-ai luat?
am ascultat si eu unul, pentru vre-o 2 ore, insuficient pentru a-mi face o parere definitiva. mi s-a parut insa destul de muzical, peste DacMagic, diferentele nefiind insa evidente.
Creaza un subiect nou   Raspunde la subiect    Pagina de start a forumului HiFi & Multimedia -> Ce sa cumpar ? Data este GMT + 3 Ore
Pagina 2 din 3
