Vand Morel Octave-Octwin 5.2M, diverse Yamaha
Du-te la pagina Anteriorul  1, 2, 3, 4, 5  Urmatorul
djradu2004
Conectat la: 14 Ian 2004
MesajTrimis: Vin Sep 24, 2010 2:35 pm    Titlul subiectului: Raspunde cu citat (quote)
Se adauga la vanzare si o pereche bookshelf-uri Dynaudio Contour 1.3 MKII + standurile originale Dynaudio Stand 4 + ambalajul original.
Stare foarte buna, nu au fost reparate sau umblate la ele, functioneaza perfect.
The Contour 1.3 MKII is a compact, two-way book-shelf speaker with enhanced bass drivers for extra stamina and power. Don't be fooled by its size - the Contour 1.3 MKII may be small, but it's capable of delivering quite a punch!
This re-designed classic now features a double magnet system that incorporates vented magnets on all drivers. The woofers have also been re-modeled to include one piece moulded MSP cones and state of the art, five-duct coil cooling systems.
In keeping with our Green philosophy, we have insisted on using environmentally friendly damping materials, combining these with acoustic stabilizing material for enhanced audio performance.
As a final touch, the re-designed Contour 1.3 MKII also features an improved multi-layer cabinet construction thanks to internal bracing which ensures maximum strength and rigidity.
http://www.dynaudio.com/eng/archive/lines/contour/contour1_3mk2.php
http://www.dynaudio.com/eng/archive/data/Contour13mkII.pdf
Cateva review-uri:
"Contour 1.3 MKII is also one of the most neutral sounded speakers Dynaudio's ever made, and they are having even better resonance measurement than the 1.3 SE and Special 25 Years according to Stereophile's test. (Check the charts for compare) It shows the lowest cabinet resonant behavior among all of them,which make them play a really pure and neutual sound!"
1:http://www.onhifi.com/product/dynaudio_contour_13mkii.htm
2:http://www.hometheaterhifi.com/volume_9_2/dynaudio-contour13-speakers-6-2002.html
3:http://stereophile.com/standloudspeakers/333/
4:http://www.audioasylum.com/audio/speakers/messages/26/263793.html
5:http://www.uhfmag.com/Issue57/Dynaudio.html
6:http://www.audioreview.com/mfr/dynaudiousa/bookshelf-speakers/contour-1-3-mkii/PRD_124580_4290crx.aspx
Dynaudio Contour 1.3 MKII Specifications
Sensitivity (2.83 V/1 m) 86 dB
IEC Long Term Power Handling 150 W
Impedanz (nominal) 4 ohms
Frequency Response 43 Hz - 24 kHz
Weight 8.9 kg
Dimensions (W x H x L) 204 x 380 x 293 mm
Sensitivity (2.83 V/1 m): 86 dB
Recommended Amp. Power: Small size rooms: >25 watts
Medium size rooms: >65 watts
Large size rooms: -- watts
IEC Long Term Power Handling: 150 watts
Impedance, Nominal: 4 ohms
Impedance, (20 - 200 Hz): 3.5 - 14.4 ohms
Impedance, (200 - 20 kHz): 3.6 - 7.6 ohms
Impedance, Phase Shift (20 - 200 Hz): -42.6� - +25.3�
Impedance, Phase Shift (200 - 20 kHz): -8.4� - +20.2�
Impedance, HF (200 kHz): 5.0 ohms
Frequency Response (+/- 2.5 dB): 43 Hz - 24 kHz
Resonance Frequency: 41 Hz
Internal Cabinet Volume: 12 litres
Bass Principle: Bass reflex
Weight: 8.9 kg
Dimensions (W x H x L): 204 x 380 x 293 mm
Crossover: 2 way. The crossover is impedance corrected
Crossover Frequencies: 2600 Hz
Crossover Slope: 6 dB/oct
Connection: Dynaudio Terminal with WBT gold binding posts
Recommended Placing: Stand (wall and book shelf with port plugs)
Remarks: Tweeter: 28 mm soft dome.
Magnetic fluid.
4 mm die cast aluminium front.
Pure aluminium wire voice coil.
Rear chamber.
Woofer: 17 cm with die cast basket and
polypropylene cone.
Cone and dust cabmoulded as one piece.
75 mm pure aluminium wire voice coil
wound on capton former.
High quality polypropylene capacitors.
Only high quality air coils are used.
PRET: 1000 EURO
Contact: 0722455615, Costin.
Nota: In pret sunt incluse si standurile originale Dynaudio Stand 4!
What one individual considers great sound can differ from another’s perspective!
MesajTrimis: Vin Sep 24, 2010 2:35 pm    Titlul subiectului: Mitica
 Filesize:  18.04 KB
 Viewed:  272 Time(s)
 Filesize:  19.56 KB
 Viewed:  205 Time(s)
 Filesize:  20.9 KB
 Viewed:  201 Time(s)
djradu2004
MesajTrimis: Vin Oct 01, 2010 12:30 pm    Titlul subiectului: Up! Raspunde cu citat (quote)
poze yamaha...
 Filesize:  60.76 KB
 Viewed:  73 Time(s)
 Filesize:  94.24 KB
 Viewed:  65 Time(s)
 Filesize:  105.72 KB
 Viewed:  64 Time(s)
Ultima modificare efectuata de catre djradu2004 la Lun Dec 13, 2010 11:07 am, modificat de 1 data in total
djradu2004
MesajTrimis: Vin Oct 08, 2010 12:51 pm    Titlul subiectului: Raspunde cu citat (quote)
Up!
djradu2004
MesajTrimis: Vin Oct 15, 2010 10:52 am    Titlul subiectului: Raspunde cu citat (quote)
Reducere de preturi!
djradu2004
MesajTrimis: Vin Oct 22, 2010 12:13 pm    Titlul subiectului: Up! Raspunde cu citat (quote)
Up!
djradu2004
MesajTrimis: Vin Oct 29, 2010 10:12 am    Titlul subiectului: Up! Raspunde cu citat (quote)
O noua reducere de preturi (vezi prima pagina).
djradu2004
MesajTrimis: Vin Noi 05, 2010 12:36 pm    Titlul subiectului: Up! Raspunde cu citat (quote)
Va astept la auditii!
Poze morel...
 Filesize:  378.49 KB
 Viewed:  113 Time(s)
 Filesize:  233.2 KB
 Viewed:  128 Time(s)
 Filesize:  208.47 KB
 Viewed:  134 Time(s)
djradu2004
MesajTrimis: Vin Noi 12, 2010 9:27 am    Titlul subiectului: Up! Raspunde cu citat (quote)
Up!
djradu2004
MesajTrimis: Vin Noi 19, 2010 8:16 pm    Titlul subiectului: Raspunde cu citat (quote)
Up!
djradu2004
MesajTrimis: Lun Noi 29, 2010 11:24 am    Titlul subiectului: Reducere de pret! Raspunde cu citat (quote)
Reducere de pret la incintele Morel Octave-Octwin 5.2M pana la sfarsitul anului: 2499 euro (fix la jumatate de pret fata de pretul oficial:http://www.avstore.ro/boxe/morel-octwin-5-2m/ )
djradu2004
MesajTrimis: Lun Dec 06, 2010 1:46 pm    Titlul subiectului: Up! Raspunde cu citat (quote)
Pentru cine cumpara incintele Morel pana la sfarsitul anului primeste si o pereche de cabluri solide de boxe cupru DIY (2 x 2,5m lungime).
djradu2004
MesajTrimis: Lun Dec 13, 2010 11:09 am    Titlul subiectului: Up! Raspunde cu citat (quote)
Up!
djradu2004
MesajTrimis: Lun Dec 20, 2010 11:09 am    Titlul subiectului: Raspunde cu citat (quote)
Reducere de pret la incintele Morel la 2399 euro + cabluri de boxe cupru DIY de 2,5m lungime.
djradu2004
MesajTrimis: Lun Dec 27, 2010 12:41 pm    Titlul subiectului: Up! Raspunde cu citat (quote)
djradu2004
MesajTrimis: Lun Ian 03, 2011 1:19 pm    Titlul subiectului: Up! Raspunde cu citat (quote)
La Multi Ani!
Pagina 4 din 5
