cele mai bune statii technics...
quit
Conectat la: 04 Dec 2006
MesajTrimis: Mie Iun 27, 2007 7:21 pm    Titlul subiectului: cele mai bune statii technics... Raspunde cu citat (quote)
am si eu un model de technics SU V90D cam ce valoare ar avea o piesa de genul asta si daca puteti sa imi dati si mie un link cu date tehnice nu ma supar:)
MesajTrimis: Mie Iun 27, 2007 7:21 pm    Titlul subiectului: Mitica
florin_shopy
Conectat la: 19 Ian 2006
MesajTrimis: Mie Iun 27, 2007 7:27 pm    Titlul subiectului: Raspunde cu citat (quote)
Technics SU-V90D integrated amplifier.
Very high specification integrated amplifier.
This amplifier is unusual as it has a built in 4 x 18 bit digital audio converter via coaxial or optical digital input.
Ideal if you have an older 16-bit CD player, DAT or even cable/free view & want to hear higher fidelity.
Automatic locking of sampling frequency 32/44.1/48 Khz.
Includes lot of features:
* MM/MC phono stage,
* tuner,
* CD,
* AUX,
* Two tape inputs,
* Digital input,
* Two sets of speaker outputs (switchable on front),
* Loudness,
* Bass,
* Treble (defeatable),
* Balance,
* Headphone socket,
* Muting,
* VC4 Class AA amplifier system,
* Power amp direct (bypasses all tone, filters etc for purer sound).
Gusty bass, sound smooth & dynamic.
More transparent & clean through the power amp direct inputs.
Listening to freeview through this amp is a complete revelation didn’t realise a freeview box could have geniune fidelity (digial input).
* Technics high speed smoothing caps in anti resonant housing,
* Large OFC frame transformer & chassis bars for less resonance.
* Rated power 115 watts per channel RMS into 8 ohms & 150 watts into 4 ohms continuous per channel.
* Suitable speakers should be rated between 4-16 ohms.
* 43cm W x 45cm D x 16cm H.
* Weighs 14kg.
* Made in Japan.
* Power consumption 765 W.
link :
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200113600246&indexURL=0&photoDisplayType=2#ebayphotohosting
Pretul din link mi se pare aberant, am vandut statia asta de curand in stare perfecta cu 700 ron.
momolo
MesajTrimis: Mie Iun 27, 2007 11:04 pm    Titlul subiectului: Raspunde cu citat (quote)
Citat:
Cand am vazut poza pe link mi-am dat seama! Am auzit si vazut for the first time statia asta in anii '80 la un tip care tragea benzi pe bani. Cumparata de noua de pe piata neagra. O caruta de bani! Era pe Unitra 140W si testata pe pickup (Technics, ala faimos direct drive). Tin minte ca stiam pe dinafara ce pot boxele alea (ca aveam si eu la fel si pentru ca le auzisem la omul ala pe multe amplifuri) dar de data aia m-a lasat cu gura cascata. Probabil si pentru ca m-a impresionat tin minte atat de bine o intamplare de atata timp! Discurile vinil folosite erau numai dealea noi americane din sursele stiute, deci discuri foarte bune, bune si azi daca le gasim!
Evident, pe vremea aia aveam cu totul alt nivel de apreciere si pretentii. Si nici cu ce compara insa tin bine minte ca suna impresionant!
Ulterior, prin anii 90 am auzit (mai mult cu ghilimele) statia asta la un trancotar care vindea cu gramada. A testat mai multe amplifuri pe niste boxe "facute" (vai mama lor, dealea, le stiti unii dintre voi). Bubuiala era de baza si cat de tare vibra sub talpa. Technics-ul asta a facut de ras tot teancul printre care se aflau si Pioneer sau Onkyo. Chiar si pe galetzile alea se simteau diferente chiar oneroase. Asta a fost de departe cea mai ok statie!
Cred ce pe atunci Technics facea statii bune. Defapt am mai scris si alta data daca tin bine minte. Ei s-au nasulit in anii 90 cand au inceput cu plasticele alea jenante, din pacate inainte sa apara in RO primele magazine unde mergeam unii dintre noi ca la Meca (iar multi nu s-au trezit nici azi!).
EinarN
Conectat la: 26 Dec 2005
MesajTrimis: Mie Iun 27, 2007 11:23 pm    Titlul subiectului: Raspunde cu citat (quote)
Asta din linkul ebay e ..... Statie ? de care de..... Autobuz sau de tramvai?
Asta-i aiureala de 3 lei.
EinarN
MesajTrimis: Mie Iun 27, 2007 11:33 pm    Titlul subiectului: Raspunde cu citat (quote)
Daca discutam de Technics, atunci numai asa ceva:
Preu Technics SU-C 1000:
Final Technics SE-A 1000:
Restul, este apa de ploaie de 3 lei, trancota de ebay si n-are ce cauta īntr-o colectie care se respecta.
Netcrusher
Conectat la: 13 Mai 2005
MesajTrimis: Mie Iun 27, 2007 11:37 pm    Titlul subiectului: Raspunde cu citat (quote)
EinarN, te bagi ca musca-n lapte.
Ceea ce prezinti tu e un amplificator absolut jenant. Am avut, si e oribil. In afara de designul frumos, de ace, nimic nu e de capul lui.
Sunt sigur ca acest SU-V90D suna mult mai bine, fapt dovedit si de alte modele mult mai vechi celor prezentate de tine.
EinarN
MesajTrimis: Mie Iun 27, 2007 11:45 pm    Titlul subiectului: Raspunde cu citat (quote)
Netcrusher a scris:
Fara intentie
Citat:
Nu cumva era de vina preul? eu am avut problema asta si am schimbat preul īn garantie.
Le luasem noi din magazin īn 1994. Numai finalul costase 1000 DM. Ajuns acasa dupa vreo 3 luni de utilizare am avut parte de aces sunet jenant cum īl denumesti tu. dupa o discutie detailata cu tehniceanul din HiFi shop-ul de unde le cumparasem, se constatase ca reul avea un defect din fabricatie. era un lot īntreg unde erau o groaza de reclamatii si īn cele din urma sa retras īntregul lot. Mie mi-au īnlocuit preul cu un altul fiind scula īn garantie si atunci s-a schimbat totul. Era o diferenta ca īntr-e cer si pamīnt. avea un "sound" de te īnebunea nu alta. Le-am tinut pīna anul trecut dupa care s-au dus la ebay.
Netcrusher
MesajTrimis: Mie Iun 27, 2007 11:49 pm    Titlul subiectului: Raspunde cu citat (quote)
Nu cred sa fi fost preul, ale mele erau MK2 si au fost ale unui prieten, de noi, au costat peste 1000DM cand le-a luat el si apoi au ajuns impecabile la mine. Eu le-am dat, tocmai din cauza sunetului. La fel, am mai auzit Technics si gama noua, si veche, si parca cea veche suna mai bine, dar aspectul nu e la fel de atragator.
RazvanVoicu
Conectat la: 22 Aug 2006
MesajTrimis: Joi Iun 28, 2007 12:07 am    Titlul subiectului: Raspunde cu citat (quote)
As mai completa cu urmatorul linck-> http://www006.upp.so-net.ne.jp/freakbeatfreak/ apoi clic pe Freack Audio si apoi "Integrated Amplifiers" nu am dat link-ul direct pentru ca e interesant de vazut tot situl Laughing
momolo
MesajTrimis: Joi Iun 28, 2007 12:38 am    Titlul subiectului: Raspunde cu citat (quote)
Citat:
Thumbs up
Tocmai ce am postat mai sus uitand ca o musca bazaie si polueaza TOATE discutiile pe aceste subiecte.
EinarN
MesajTrimis: Joi Iun 28, 2007 1:16 am    Titlul subiectului: Raspunde cu citat (quote)
momolo a scris:
Mda........... si tu esti MISTER PERFECT, guru-ul forumului care l-e sti pe toate cel mai bine. Daca cineva īsi expune punctul de vedere, īti polueaza tie perfectiunea cunostintelor daca nu este de aceasi parere cu tine.
Esti asa de "tolerant" si "onest" ca o mīta spīnzurata de coada.
RazvanVoicu
MesajTrimis: Joi Iun 28, 2007 1:19 am    Titlul subiectului: Raspunde cu citat (quote)
M-am stricat de ras, dar stiti cum...... Laughing Laughing Laughing ma doare burta, mmmmmwuuuuuhahahahahahahahahahaha, HAHAHAHAHAHAHAHA, hihihihihihihihihihihihi , daca ati fi incercat sa spuneti o poanta de top pe care ar fi stiut-o toata lumea si numai eu nu, cred ca n-as fi ras asa....... Doamne....... hahahahahahahahahahaha, MMMMMWUUUUUHAHAHAHAHAHAHAHA, HIHIHIHIHIHIHIHIHIHI!))))))))))
RazvanVoicu
MesajTrimis: Dum Iul 01, 2007 9:29 pm    Titlul subiectului: Raspunde cu citat (quote)
Cateva detalii despre "referintele" lor in domeniu nu cred ca strica -> http://audio-heritage.jp/TECHNICS/amp/index2.html
Eltax
Conectat la: 01 Apr 2007
MesajTrimis: Joi Noi 22, 2007 7:38 am    Titlul subiectului: Raspunde cu citat (quote)
ati uitat de batranul Technics Sa-500k ? a aparut in 1978-79 . Il am si acum merge perfect . : Laughing <a href="http://tinypic.com" target="_blank"><img src="http://i5.tinypic.com/6y4yntu.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
Eltax
[quote="Eltax"]ati uitat de batranul Technics Sa-500k ? a aparut in 1978-79 . Il am si acum merge perfect . : Laughing
Varianta īn limba romānć: Romanian phpBB online community
