[VAND:] HDCD, XRCD, MFSL, GOLD CD, SACD
Du-te la pagina Anteriorul  1, 2, 3, 4, 5  Urmatorul
XRCD24
Conectat la: 11 Noi 2005
MesajTrimis: Dum Dec 23, 2007 8:12 pm    Titlul subiectului: [OFERTA] BLACK & WHITE NF1202 REFERENZ !!! Raspunde cu citat (quote)
Ultima modificare efectuata XRCD24 la Lun Noi 01, 2010 8:52 am, modificat de 3 ori in total
MesajTrimis: Dum Dec 23, 2007 8:12 pm    Titlul subiectului: Mitica
XRCD24
MesajTrimis: Dum Ian 06, 2008 7:44 pm    Titlul subiectului: Raspunde cu citat (quote)
Ultima modificare efectuata XRCD24 la Mie Noi 17, 2010 3:50 am, modificat de 6 ori in total
XRCD24
MesajTrimis: Dum Feb 17, 2008 11:34 pm    Titlul subiectului: [VAND] CELE MAI AUDIOFILE CD-uri ! ! ! Raspunde cu citat (quote)
Ultima modificare efectuata de catre XRCD24 la Mie Noi 17, 2010 4:26 am, modificat de 1 data in total
XRCD24
MesajTrimis: Dum Feb 24, 2008 8:06 pm    Titlul subiectului: MUSICAL REFERENCE DVD-Audio&Video Raspunde cu citat (quote)
DVD-Audio and DVD-Video REFERENCE S°U°R°R°O°U°N°D
Over 1 hour of exemplary high resolution classical recordings.
The pieces where recorded in different rooms, from a small chapell to
a huge cathedral, wich takes the listener to a fascinating sound journey.
This high quality 5 channel DVD-recording makes You hear the obvious
sound characteristics and differences of the different acoustic enviroments
the recordings where captured in.
PRET : 20 EURO
XRCD24
MesajTrimis: Lun Mar 17, 2008 12:35 am    Titlul subiectului: Raspunde cu citat (quote)
Ultima modificare efectuata XRCD24 la Vin Mar 20, 2009 6:40 am, modificat de 6 ori in total
XRCD24
MesajTrimis: Lun Mar 24, 2008 12:51 am    Titlul subiectului: [VAND] CD / XRCD / SACD uri FOARTE ! ! ! AUDIOFILE Raspunde cu citat (quote)
O "ADEVARATA" CAPODOPERA ACUSTICA !!!!!
LARRY WILLIS ° STEAL AWAY
[AUDIOQUEST / Recorded at MAPLESHADE STUDIOS !!]
A SE ASCULTA AICI:
http://www.allmusic.com/cg/amg.dll?p=amg&sql=10:3cfwxq9gldke
Ultima modificare efectuata XRCD24 la Mar Dec 01, 2009 4:53 am, modificat de 7 ori in total
cipsideil
Conectat la: 18 Feb 2004
MesajTrimis: Mar Mar 25, 2008 2:01 pm    Titlul subiectului: Raspunde cu citat (quote)
Salut. Ai MP
XRCD24
MesajTrimis: Dum Mar 30, 2008 11:09 pm    Titlul subiectului: [VAND] MEGA-AMPLIF LAMPI / ULTRA-AUDIOFIL !! Raspunde cu citat (quote)
SPARK / CAYIN 810 ° Modele DEMO, optic & functional IMPECABIL!
MONO-BLOACE 2 x 34 KG / ULUITORI 100 WATTI !!!!
DINAMICA, TRANSPARENTA, RAFINAMENT la MAXIM !!!!
PRET OFFICIAL 5999,99 EURO !!
PRET DISCOUNT 3000 EURO / LIVRARE LA DOMICILIU INCLUSA !!!!
DEASEMENEA INCLUS IN ACEST PRET, PREAMPLIFICATORUL PE LAMPI
VINCENT LS1 [Poze gasiti mai jos in anunt!]
PRET DISCOUNT 06.07.2008 : 2800 EURO (LIVRARE INCLUSA !!)
Like all Cayin products, the 810 boasts:
Hand made point-to-point wiring and workmanship better than any product at its price range.
Heavy gauge-vented chassis with an automotive lacquer finish to ensure a solid platform and elegant look.
Potted toroidal power transformers known for their lower stray magnetic fields that enables them to run cooler and quieter (no hum).
Soft-start circuit (30 seconds) and conservative design runs the tube easy and powers it up gently for extended tube life.
Tube plate fuse protects the amp output stage
Aeronautics quality control standards. 1 week continuous factory burn-in to ensure quality.
VINCENT LS-1 ° Preamplificator pe lampi!
Inclus in pret la oferta MONO-BLOACE 2 x 34 KG SPARK / CAYIN 810,
disponibil si separat / PRET : 300 EURO
Ultima modificare efectuata de catre XRCD24 la Dum Iul 06, 2008 4:31 pm, modificat de 1 data in total
XRCD24
MesajTrimis: Dum Apr 13, 2008 11:12 pm    Titlul subiectului: OFERTA CABLURI [AUDIOQUEST] Raspunde cu citat (quote)
OFERTA CABLURI AUDIOFILE INTERCONECTAUDIOQUEST
RAPORT PRET-CALITATE IMBATABIL!!!
° AUDIOQUEST CORAL
AudioQuest Coral is a Triple Balanced cable featuring Hyperlitz
construction.
Coral uses three solid PSC copper conductors, each insulated
with foamed Polyethylene. When used single-ended (with RCA plugs),
one conductor carries the positive audio signal, two carry the negative.
The 100% coverage shield is only attached at one end so that it is not
used as an inferior audio conductor.
AudioQuest's Coral attended to the middle range with a perspective
that was slightly less forward than the Nordost and Kimber.
It conveyed a warmer, rounder personality that would match well
with leaner, cooler systems. Its soundstaging was appreciably wide
and deep on orchestral material.
PRET OFFICIAL : 2 X 50 cm / 159,99 EURO !!!
PRET DISCOUNT : 100 CM / 40 EURO !!!!!!
° AUDIOQUEST COPPERHEAD
AudioQuest Copperhead uses two solid PSC copper conductors in
the symmetrical Hyperlitz arrangement.
One conductor is insulated and used for positive. The other is
uninsulated and makes contact with the 100% coverage shield,
allowing it to connect (drain) the shield while at the same time
being used as a high quality conducting path for the negative
signal. This black PVC jacketed version of this cable carries a
UL CL-3 rating, enabling it to be used inside walls without conduit.
PRET OFFICIAL : 2 X 50 cm / 109,99 EURO !!!
PRET DISCOUNT : 100 CM / 20 EURO !!!!!!
Cablurile sint NOI!, dar ne-confectionate!
Pentru cine este interesat, sint mai multe bucati NOI / NEFOLOSITE disponibile !!!
Ofer si la fiecare bucata de 1,0 metruGRATUIT! un set de 4 mufe
"gen WBT" (evident nu comparabile cu acestea ca si calitate, dar pe
exact acelasi principiu de functionare!!)
Ultima modificare efectuata de catre XRCD24 la Mie Iul 29, 2009 4:54 pm, modificat de 1 data in total
XRCD24
MesajTrimis: Vin Mai 30, 2008 7:55 pm    Titlul subiectului: [OFERTA CABLURI DE BOXE AUDIOQUEST TYPE 4 / CV 4 / F 14 ] Raspunde cu citat (quote)
3 CABLURI DE BOXE LEGENDARE CONSIDERATE ETALOANE IN GAMA LOR
DE PRET, REDUSE SEMNIFICATIV LA PRET, DISCOUNT INTRE 40-60% !!!!!!
CALITATE F E N O M E N A L A LA PRET ACCESIBIL !!!!!!
[OFERTA : AUDIOQUEST TYPE 4 +]
[ULTIMA VERSIUNE A LEGENDARULUI CABLU!!]
http://img223.imageshack.us/img223/3097/h703t410bfsoprofile.jpg
http://img212.imageshack.us/img212/6207/type4drawing.jpg
Stereophile Magazine Recommended Component
Excellent-value AudioQuest Type 4 gets the "Recommended Component" nod
from Stereophile. Other reviewers are crazy about it, too. "If you've gotten
the impression that I liked AudioQuest's Type 4 speaker cable, you're quite
correct," writes Greg Smith in the June 1998 issue of SoundStage. "I haven't
heard anything less expensive than this that is as well balanced and appropriate
for such a wide range of systems."
Type 4 is a high-tech, four-conductor, solid LGC copper cable featuring PE poly-
-ethylene insulation, carbon-loaded polyethylene dielectric, and a PVC cover.
These cables are terminated at AudioQuest's factory using silver-base solder
and high-quality gold .25" spades. They are then wrapped in protective plastic.
"This is an excellent cable," marvels Britain's Home Entertainment magazine
in issue 64. "Type 4 has a fuller and more vibrant palate of tonal colours and
textures than most. The treble is detailed, and instruments and voices are well
separated, yet the treble is also well controlled, lacking the forward quality and
assertiveness of some."
Ordinary Price, Extraordinary Cable
Type 4 might look like a normal round cable, but inside is a fully optimized
combination of extraordinary materials and extremely refined design. All four
of Type 4's conductors are solid. Electrical and magnetic interaction between
strands in a conventional cable is the single greatest source of distortion, often
causing a somewhat harsh, dirty and confused sound. Solid conductors are the
most important ingredients of Type 4's very clear sound. Whether a conductor
is solid or stranded, skin-effect is a prime distortion mechanism in speaker
cables. Type 4 very simply keeps this effect out of the audio range by using
conductor sizes that are below the threshold for audible distortion.
A Super Sonic Technology
SST stands for Spread Spectrum Technology, an AudioQuest cable innovation.
Any single size or shape of conductor has a specific distortion profile. SST
significantly reduces distortion by using a precise combination of different size
conductors. SST has enabled Type 4 to be the biggest possible four conductor
cable that avoids audible skin-effect.
Conductors are made of LGC (Long Grain Copper), which has a pure surface
for focused sound and excellent signal transfer. The helical array construction
allows for significantly better dynamic contrast and information intelligibility
than if the same conductors were run in parallel.
Type 4 cable is UL / CL3 certified for in-wall use. Its combination of economical
price and great performance makes it ideal for multi-room systems.
2 x 1,5 METRII / CONFECTIONAT ORIGINAL DE FABRICA !!
PRET OFFICIAL : 120 EURO
PRET DISCOUNT - 50% !!!!! : 60 EURO
2 x 3 METRII / CONFECTIONAT ORIGINAL DE FABRICA !!
PRET OFFICIAL : 200 EURO
PRET DISCOUNT - 50% !!!!! : 100 EURO
PENTRU CINE DORESTE SA FACA SI MAI MARI ECONOMII
METRU LINEAR :
ATENTIE : mai sint disponibile doar circa 20 metrii!!
PRET OFFICIAL : 15 EURO
PRET DISCOUNT - 40% !!!!! : 9,00 EURO (VARIANTA "ELEGANTA" IN TESUT!)
[OFERTA : AUDIOQUEST CV 4]
PRET OFFICIAL : 220 EURO
PRET DISCOUNT - 60% !!!!! : 100 EURO
PRET OFFICIAL : 350 EURO
PRET DISCOUNT - 60% !!!!! : 140 EURO
METRU LINEAR :
PRET OFFICIAL : 35 EURO
PRET DISCOUNT - 50% - 2,50 EURO !!!!! : 15,00 EURO
Using the same solid-core SST geometry as the AQ Type-4, the CV-4
sonic improvement is a result of the PSC (Perfect Surface Copper) used
in its manufacturing. This unique metal allows the CV-4 to out-perform
previous AudioQuest cables that cost several times as much.
The level of focus, transparency and detail are unprecedented at this price.
[OFERTA : AUDIOQUEST F 14e ]
Un cablu F-E-N-O-M-E-N-A-L !!!!!!!!!!!
La un pret de nimic acest cablu ofera mult din "sound-ul" tipic AUDIQUEST!
Energetic, cu un bass puternic si inalte "muzicale" acest cablu este oarecum
opusul cablurilor bugetare KIMBER care suna ceva mai detaliat, insa stridente,
obositoare si au evident un minus la capitolul BASS in comparatie cu AUDIOQUEST!
PRET OFFICIAL : 4,99 EURO / metru
PRET DISCOUNT : 3,50 EURO / metru
AudioQuest F-14 is flat! The third generation SST version of F-14 is 0.45" (11.4mm)
wide and only 0.10" (2.5mm) thick. In addition to excellent sound, easy preparation
and low cost, F-14 runs neatly under carpets or along baseboards and up walls.
F-14 uses four solid LGC (Long Grain Copper) conductors; 2 x 21 awg and 2 x 18 awg.
One of each size for positive and one of each for negative, making 16 awg (1.23 sq. mm).
All strands are spaced apart, making this a flat Hyperlitz cable. F-14 is available in blue
or white.
Ultima modificare efectuata XRCD24 la Mar Dec 22, 2009 3:04 am, modificat de 4 ori in total
XRCD24
MesajTrimis: Dum Iul 27, 2008 11:10 pm    Titlul subiectului: [VAND : CABLU DIGITAL de 400 EURO la 15 EURO !!!] Raspunde cu citat (quote)
PURE SOLID-SILVER DIGITAL CABLE /
NEOTECH ND-021080 aka ECOSSE 'THE SOUNDMAN'
ARGINT DE MARE PURITATE!!!
TRIPLU ECRANAT!!!
CONSIDERAT CEL MAI BUN / "PRECIS" CABLU DIGITAL!!!
° Sub numele ECOSSE / THE SOUNDMAN 1/2 METRU costa 400 EURO !!!!!
http://www.stoneaudio.co.uk/browse.asp?product=2546
° Ofer la "numai" 15 EURO, bucati de 1/2 metru
° ...... la "numai" 25 EURO, bucati de 1 metru
:: SI ALTE LUNGIMI DISPONIBILE !! ATENTIE : STOCK LIMITAT !!
Ofer si la fiecare bucata de 1/2 metru
GRATUIT! un set de 2 mufe
DESCRIERE :
Triple shielded (Cu-foil and 2 * SPC braid, teflon foil between them), pure solid silver digital cable in dark grey PVC jacket. Cross-section of the internal wire is 0,33 mm2.
It has often been said that the best digital interconnect in the world (in real-world price terms) is the old Kimber Illuminati D60. (Hey we don't mind name checkin' a brother…). Of course, Kimber no longer produce this interconnect (as Ray himself did not actually design it). NO MORE…because The Ecosse Soundman creams the old Illuminati BIG TIME!!!
Here's how: It is vital that 'reference' quality digital cable closely matches the 'characteristic impedance' (75ohm) of the digital signal- this being the most important concern of digital signal transmission. Of near-equal importance is 'capacitance'-which must be kept as low as possible. The topology of ''The Soundman" digital interconnect is carefully controlled to precisely match these required specifications-it is a precision 75 ohm cable designed to provide the highest quality single-ended digital interface and of especially low capacitance. The signal conductor is made from a perfectly circular solid wire of 6N's silver.
Ultra low-loss Foamed Polyethylene forms the dielectric insulator and the former for the first two of three screens. A pure copper foil is surrounded by a close-lapped braid screen of silver-plated Ultra-Hi Purity OFC. A layer of PTFE (Teflon) separates this screen from an outer screen of the same close-tapped silver plated UHP-OFC. Such a screen fully protects the digital bit stream from the distortions introduced by RFI, EMI and ESI 'noise'. It is necessary and appropriate to ground this type screen at 'source' only- for maximum noise reduction. A layer of Neoprene™, acting as a damper and vibration absorber is sandwiched between the outer screen and the soft PVC outer jacket.
Developed with the best transports, DAC's and digital amplifiers in mind, "THE SOUNDMAN" propagates a full bandwidth signal within an ultra low noise environment that ensures the most accurate signal transfer possible and represents Ecosse's 'statement' digital transmission product.
XRCD24
MesajTrimis: Dum Aug 17, 2008 4:21 pm    Titlul subiectului: [VAND : CABLU INTERCONECT de 1100 EURO la 110 EURO !!!!!] Raspunde cu citat (quote)
DEFINITIV !!!!! CEL MAI PERFORMANT INTERCONECT SUB 1000 EURO !!!!!
ULTRA-PURE UPOCC SOLID-SILVER INTERCONECT CABLE /
NEOTECH NA-12165 aka ECOSSE 'THE LEGEND'
ARGINT DE CEA MAI MARE PURITATE!!! / TRIPLU ECRANAT!!!
CONSIDERAT UNUL DIN CELE MAI PERFORMANTE CABLURI INTERCONECT
DIN LUME, .....INDIFERENT DE PRET!!!!! SI ASTA PE DREPT!!!!!
DEADREPTUL "DE-CLASEAZA" CONCURENTA IN CLASA SA DE PRET,
DIFERENTELE SONICE PE INTREAGA BANDA DE FRECVENTA FIIND
D R A M A T I C E!!!!! CONCURENTA "REALA" SE REGASESTE ABIA LA 2-3000 EURO!!!!!
CISTIGUL IN DETALIU SI DINAMICA ESTE ATITA DE MARE CA ESTE EVIDENT
SESIZABIL INSTANTANEU, PINA SI DE URECHI "NE-EDUCATE" AUDIOFIL!!!!!
Monocrystal™ Pure Silver 7N purity Balanced solidcore conductors!!
Triple Al foil + close-lapped SP-UHP-OFC™ braid + Teflon screen!!
Teflon™ (PTFE) Superlative low-loss dielectric + ‘airspace matrix’ helical construction!!
Virtually zero microphony!!
PRICES BEGIN AT "JUST": RCA £899.00 / 0.5m pr; XLR £1004/0.5m pr
° Sub numele ECOSSE / THE LEGEND 2x1/2 METRU costa 1100 EURO !!!!!
° Ofer la "numai" 110 EURO, bucati de 1 metru
° ...... la "numai" 200 EURO, bucati de 2 metrii
Ofer si la fiecare bucata de 1 metru
DESCRIERE :
The Ecosse research and development team, realising the need for an interconnect offering conductor materials of even faster transmission speeds than grain-free Monocrystal™ copper - whilst absolutely maintaining its purity, clarity and sheer brilliance - introduce the 'The Legend' Ultra-Pure Monocrystal™ / UPOCC Silver Interconnect.
The Legend is our 'statement interconnect' yet imposes no statement of its own. Utilising Monocrystal™ Silver solidcore conductors of 7N purity, probably the best conductor available at room temperature, this interconnect undoubtedly defines the 'state of the art' at its price.
MONOCRYSTAL™ Pure Silver is Ecosse's pioneering commitment to conductor material development ensuring, uniquely, a complete lack of 'grain-boundaries' in the signal transmission direction - impurities which would normally impede the delicate audio or video signals and result in attenuation and distortion.
Here, a unique casting process (extrusion and annealing in an inert gas environment) is employed to produce a 'mono' or single crystal ultra-pure wire with significant advantages over other cables currently available. These other cables use ordinary silver, which, no matter how few grains the manufacturer claims, have a grain barrier of oxygen and hydrogen and in some cases, a high level of metallic impurities.
Monocrystal™ patented silver cables are technically unsurpassed for their quality and their ability to transmit audio and video of the highest quality with minimal distortion and attenuation from grain boundaries - BECAUSE THERE ARE VIRTUALLY NO BOUNDARIES!
This cable is acclaimed as having an "…incredible sound" and deemed…'perversely good value for money against interconnects at twice the price' in the Hi-Fi News review of the original in 2002...oh and did we mention it won EDITOR'S CHOICE CABLE OF THE YEAR from Hi-Fi News that year?
Suffice to say 'The Legend' easily exceeds the requirements of the new 'super audio' formats, with their wide dynamic range and extended frequency response. This is not an inexpensive audio interconnect. However, compare its price to the £1000+ charged by our competitors for their high-end interconnects and you immediately see the cost-effective benefits of an Ecosse Reference interconnect -especially at the 'high-end'.
Conventional descriptions and terminology cannot do justice to the performance of this cable. With commensurate hardware, experience all of the intentions and commitment of the original performance.
Be astounded by your presence at the recording studio/venue!
Ultima modificare efectuata XRCD24 la Vin Oct 17, 2008 3:47 am, modificat de 2 ori in total
XRCD24
MesajTrimis: Mar Oct 28, 2008 8:59 pm    Titlul subiectului: Raspunde cu citat (quote)
Ultima modificare efectuata de catre XRCD24 la Dum Apr 26, 2009 10:44 pm, modificat de 1 data in total
Jaya77
Conectat la: 28 Feb 2008
MesajTrimis: Dum Noi 09, 2008 1:11 pm    Titlul subiectului: Raspunde cu citat (quote)
Aveti mesaj pe MP
XRCD24
MesajTrimis: Lun Noi 17, 2008 12:54 pm    Titlul subiectului: [ SUPER-OFERTA !! : VINCENT CDS3 / CD-player ] Raspunde cu citat (quote)
Ultima modificare efectuata XRCD24 la Dum Apr 26, 2009 10:45 pm, modificat de 2 ori in total
Pagina 2 din 5
Varianta în limba românã: Romanian phpBB online community
