Zuby
Conectat la: 11 Mai 2007 Mesaje: 47 Locatie: Bucuresti
Trimis: Mar Oct 02, 2007 8:14 pm Titlul subiectului: Technics SU-V90D.SE-A909.Onkyo.Pioneer A-757.Sony Qs |
Amplificatoare:
-Technics SU-V90D,Mos class AA,cap de serie,optic,950RON
-Technics SE-A909+SU-C800,Mos class AA,telecomanda,480E.
-Power Onkyo M-5030, 550E.
-Pioneer A-757,Reference Class,300E.
Receivere:
-Sony STR-DB798Qs 7.1,7x135W,6 intrari digitale,950RON.
-Technics SA-DA10 GOLD,telecomanda,400E.
-Technics SA-DX950,MosFet,telecomanda,850RON.
-Tuner Pioneer F204 RDS,280RON.
Eq:
-Kenwood GE-5020,400RON.
Deck:
-Pioneer CT-757,Hx-Pro,400RON.
Cd Playere:
-Technics SL-PG590,250RON.
Boxe:
-Technics SB-M800, 1600E.
-Pioneer S-H520Q,130W,8ohm,850RON.
Nr contact: 0723684736. mail: zuby_c_andy@yahoo.com
Ultima modificare efectuata Zuby la Mar Apr 19, 2011 11:28 am, modificat de 197 ori in total |
Trimis: Mar Oct 02, 2007 8:14 pm Titlul subiectului: Mitica |
338.57 KB |
290 Time(s) |
281.17 KB |
270 Time(s) |
Zuby
Trimis: Lun Oct 29, 2007 9:15 pm Titlul subiectului: SONY QS 7x135W |
•7 x 135 W
•Gama QS
•Decodor Dolby® Digital / EX DTS® / ES / 96/24 / NEO:6
•Decodor Dolby® Pro Logic® IIX Dolby® Dual Mono
•Digital Cinema Sound integral
•Intrare multicanal (5.1), 3 intrari audio, 1 iesire audio, 5 intrari AV, 2 iesiri AV, 6 intrari digitale, 1 iesire digitala Component video, 2 intrari, 1 iesire
•Sincronizare A/V
•Crossover subwoofer în 13 puncte
•Convertor video în format S-Video
•Tuner RDS cu 30 de presetari
Culori: argintiu
Receiverul este impecabil estetic si functional ca nou,nu am telec la el,pozele sunt reale,sunet puternic si fidel si pe stereo si pe dolby.
125.44 KB |
57 Time(s) |
124.64 KB |
87 Time(s) |
Ultima modificare efectuata Zuby la Lun Feb 14, 2011 7:06 pm, modificat de 45 ori in total |
Zuby
Trimis: Mie Noi 14, 2007 11:39 pm Titlul subiectului: Poze |
Linie Hi-Fi Pioneer
-Amplificator Pioneer A-757,2x185W,Reference Class,820W consum,2 trafuri,22Kg,made in japan,300E.
-Deck Pioneer CT-757,3capete,Hx-Pro,made in japan,400RON.
-Tuner Pioneer F-204 RDS,made in japan,280RON.
Piesele sunt impecabile estetic si functional,se vand impreuna sau separat,poze reale.
130 KB |
55 Time(s) |
297.93 KB |
105 Time(s) |
Ultima modificare efectuata Zuby la Mar Apr 19, 2011 11:29 am, modificat de 38 ori in total |
Zuby
Trimis: Vin Noi 23, 2007 1:23 pm Titlul subiectului: poze |
Vand Amplificator Technics SU-V90D,2x150W,intrari optice,made in japan,amplificatorul este impecabil estetic si functional ca nou.pret 950RON.contact 0723684736
122.85 KB |
45 Time(s) |
121.22 KB |
45 Time(s) |
Ultima modificare efectuata Zuby la Mar Apr 19, 2011 11:32 am, modificat de 45 ori in total |
Zuby
Trimis: Joi Dec 06, 2007 9:14 pm Titlul subiectului: poze |
Vand amplificator Technics SE-A909+SU-C800,2x120W,Mos Class AA,V.B.O,telecomanda,poze reale.pret 480E.contact 0723684736
120.31 KB |
37 Time(s) |
114.57 KB |
35 Time(s) |
Ultima modificare efectuata Zuby la Mar Apr 19, 2011 11:56 am, modificat de 28 ori in total |
Zuby
Trimis: Sam Dec 15, 2007 9:52 pm Titlul subiectului: Linie Technics |
Vand boxe Pioneer S-H520V-QL,foarte bine intretinute,impecabile estetic si functional,nedesfacute sau reparate,poze reale.
- Bass 2 x 14cm cone woofers
- Tweeter 2.5cm dome-type unit
- Enclosure Front duct bass-reflex
- Impedance 8 Ω
- Frequency Range 40 - 20,000 Hz
- Sensitivity (2.83V/1m) 87 dB
- Maximum Power 130W
- Dimensions (W x H x D) 195 x 1,032 x 289 mm
-Weight 13.4 kg
341.26 KB |
37 Time(s) |
334.87 KB |
32 Time(s) |
Ultima modificare efectuata Zuby la Mar Apr 19, 2011 12:00 pm, modificat de 11 ori in total |
Zuby
Trimis: Joi Dec 27, 2007 6:47 pm Titlul subiectului: poze Technics SB-M800 |
Vand Boxe Technics SB-M800,200W,100W nominal,6ohm,3 cai 5 difuzoare tip Dual Dinamic Drive,30Hz-100KHz (-16dB),86dB/W/m,30Kg bucata,impecabile estetic si functional,poze reale,pret 1690E,0723684736.
119.45 KB |
1086 Time(s) |
117.86 KB |
1056 Time(s) |
121.05 KB |
1176 Time(s) |
Ultima modificare efectuata Zuby la Mie Sep 08, 2010 12:43 pm, modificat de 18 ori in total |
Zuby
Trimis: Sam Ian 05, 2008 4:20 pm Titlul subiectului: up |
Rceiver Technics SA-DA10 GOLD
Impecabil estetic si functional,ca nou,telecomanda originala,este la 110V(transformator de la 110-220V inclus),poze reale.
Technical features:
-DSP effect production:-Number of signal channels: 5-Dolby Digital (AC-3)-Digital theater-systems decoder (DTS)-Digital sound processor (DSP)
-Performance/main channels:-Optimized for sound DVD audio-Sine power per channel, 6 ohms, DIN: 100 W-Signal to noise ratio: 113 dB
Output power:DIN power (2 x 100 Watts into 6 ohms)RMS power (2 x 80 watts into 6 ohms)
in 6CH-Betriebsart:Front channels (2 x 100 Watts into 6 ohms),Mid channel "Center" (1 x 100 Watts into 6 ohms)Surround channels (2 x 100 Watts into 6 ohms)
Performance/effect channels:-Center: 100W Sinusl 6 Ohms, DIN-Front: 100 W Sinusl. Per channel, 6 ohms, DIN-Rear: 100 W Sinusl. Per channel, 6 ohms, DIN
Tuner:-Radio data system (RDS)-RDS radio text (RT)
Sound setting:-Bass controller-Height slider-Balance control
Operation:-IR-system controllable (unfortunately no service available)-Input selector-A/B speaker selector-direct frequency input-30 programmable station storage-adjustable display-Pink noise test tone generator
Connectors RCA:Phono, CD, tape/MD, DVD, TV, VCR1, VCR2, VCR3
Digital connectors:CD, DVD, TV opticaldigital audio connections:-3 x digital optical (IN)Video connections (including stereo audio):-5 x video ports, total-1 x CVBS (IN / OUT)-1 x front CVBS (IN)-3 x CVBS (IN)-1 x CVBS (OUT) without audio
Analogue audio Conn without video audio:-1 x phono (IN)-3 x audio ports o. phono total-1 x back-line (IN / OUT)-1 x back-line (IN), without phono-5.1 Channel-IN for AC-3/multi channel decoder-Subwoofer OUT (low pass)-gold-plated audio Anschlubuchsen
Speaker connectors:-Screw connectors for main-LS-Screw connectors for effect-LS-Bi-wiring connectors for main-LS
Dimensions:-Width: 43 cm-Height: 18 cm-Depth: 37 cm
Weight:-12.7 Kg
117.81 KB |
50 Time(s) |
130.71 KB |
34 Time(s) |
116.32 KB |
39 Time(s) |
Ultima modificare efectuata Zuby la Mar Apr 19, 2011 12:06 pm, modificat de 24 ori in total |
Zuby
Trimis: Sam Ian 26, 2008 6:14 pm Titlul subiectului: Sony |
up.
Ultima modificare efectuata Zuby la Sam Dec 19, 2009 11:53 pm, modificat de 14 ori in total |
Zuby
Trimis: Lun Feb 04, 2008 8:06 pm Titlul subiectului: Technics |
Deck Technics RS-AZ6,made in japan,ca nou folosit f putin,pret 450RON.0723684736
119.85 KB |
336 Time(s) |
132.67 KB |
250 Time(s) |
Ultima modificare efectuata Zuby la Mie Noi 25, 2009 12:35 pm, modificat de 12 ori in total |
Zuby
Trimis: Vin Mar 07, 2008 8:32 pm Titlul subiectului: up |
Amplificator Onkyo M-5030,2x125W 20Hz-20KHz 8ohm,2x185W 20Hz-20KHz 4ohm,constructie dual mono,18Kg,made in japan.impecabil estetic si functional,poze reale,550E.contact 0723684736 zuby_c_andy@yahoo.com
99.03 KB |
1173 Time(s) |
97.27 KB |
996 Time(s) |
65.94 KB |
901 Time(s) |
Ultima modificare efectuata Zuby la Mie Noi 18, 2009 11:05 am, modificat de 21 ori in total |
Zuby
Trimis: Lun Mar 17, 2008 3:39 pm Titlul subiectului: up |
Ultima modificare efectuata Zuby la Dum Dec 20, 2009 5:16 pm, modificat de 17 ori in total |
Zuby
Trimis: Mie Oct 08, 2008 12:23 pm Titlul subiectului: Re: Poze |
Boxe JBL E60 noi la cutie,100W nominal,8ohm,legaturi bi-wiring,18Kg buc,made in mexic,sunt cu totul alte boxe fata de cele din comert care sunt made in china,alte filtre,alte difuzoare,alt cabinet,alt sunet.poze reale,pret 350E.0723684736 zuby_c_andy@yahoo.com.
92.55 KB |
623 Time(s) |
99.44 KB |
439 Time(s) |
Ultima modificare efectuata Zuby la Mie Sep 09, 2009 5:42 pm, modificat de 11 ori in total |
Zuby
Trimis: Sam Dec 05, 2009 6:28 pm Titlul subiectului: up |
Zuby
Trimis: Sam Dec 19, 2009 11:56 pm Titlul subiectului: up |
