E bine organizat anuntul ? |
Da |
30% |
[ 16 ] |
Nu |
69% |
[ 36 ] |
Voturi totale : 52 |
sloop
Conectat la: 16 Noi 2004 Mesaje: 240 Locatie: Costesti / Pitesti / Arges
Trimis: Mar Mai 20, 2008 12:05 pm Titlul subiectului: VAND ROTEL RA-980BX, MARANTZ PM64, ECHO IO, SENNHEISER |
CONFORM SONDAJULUI MAJORITATEA NU SE DESCURCA SA URMAREASCA ANUNTUL !!!
CONTACT
YM: adisloop
Tel: 0742981568
_________________ Stereo sounds better than ever... Atoll IN80 + Dual CL730
Ultima modificare efectuata sloop la Mie Apr 27, 2011 1:00 am, modificat de 46 ori in total |
Trimis: Mar Mai 20, 2008 12:05 pm Titlul subiectului: Mitica |
sloop
Trimis: Joi Noi 20, 2008 8:05 pm Titlul subiectului: DB SONIC DB6004 |
AMPLIFICATOR AUTO DB SONIC DB6004 800W, stare buna de functionare, constructie solida, conectori de calitate.
Pret:300ron
http://www.oasis-tuning.com/mag/fr/product-309335.htm
Iluminare albastra
4 canale reglaje frecvente functioneaza si in punte.
Power Output RMS 4Ohm : 4x75W
Input Voltage Range : 200mV - 8V
Freqency Response : 20Hz 40kHz
Crossover Frequency LPF:50Hz-750Hz, HPF:50Hz-120Hz
Phase Shift : 0° - 180°
Bass boost : 0 - 18dB
Variable subsonic filter: 20Hz-50Hz
Dimension (LxHxP) : 285x58x290mm
161.34 KB |
120 Time(s) |
179.09 KB |
97 Time(s) |
180.05 KB |
85 Time(s) |
Ultima modificare efectuata sloop la Vin Dec 03, 2010 5:17 pm, modificat de 34 ori in total |
sloop
Trimis: Lun Feb 16, 2009 11:28 am Titlul subiectului: up |
Subwoofer auto in stare perfecta, BOSS SBP-12, incinta bandpass, difuzor 30cm, putere 400W RMS/800W MAX.
Pret: 350ron
http://www.dommel-caraudio.nl/?page=catalog&view=product&product_id=1255
BOSS SBP-12 specs:
-Bandpass system
-300mm (12 ") Subwoofer Series Ripper
-800 Watts Peak / 400 Watts RMS
-Frequency response: 25Hz - 2.5 kHz
-Impedance: 4 ohms
-Efficiency: 95dB (1 watt / 1 meter)
-Dimensions: 275 (H) x 400 (W) x 385 (D)
-Weight: 15kg +
37.57 KB |
179 Time(s) |
90.73 KB |
198 Time(s) |
Ultima modificare efectuata sloop la Joi Ian 06, 2011 5:37 pm, modificat de 31 ori in total |
sloop
Trimis: Lun Feb 23, 2009 10:56 pm Titlul subiectului: --- |
Minidisc portabil GRUNDIG MD-P1, 40s antishock, carcasa aluminiu, telecomanda cu display luminat, pachet complet (player, telecomanda, casti, alimentator original, cutie), functioneaza cu o baterie normala AA de 1.5V sau cu 1 acumuator.
Identic cu Audiophase MDP-1: http://www.minidisc.org/part_Audiophase_MDP-1.html
Pret: 100ron sau schimb cu diverse
17.25 KB |
88 Time(s) |
45.91 KB |
89 Time(s) |
Ultima modificare efectuata sloop la Vin Mar 25, 2011 8:48 pm, modificat de 36 ori in total |
sloop
Trimis: Joi Mar 25, 2010 7:18 pm Titlul subiectului: up |
Amplificator Marantz PM64, 2x100w/8ohm sau 2x140w/4ohm culoare argintie, destul de bine lucrat, 4 filtraje, cate 2 finali de 17A pe canal, stare buna, nereparat.
Form Integrated Amplifier
Output power 100W+100W (8 ohms, 20Hz - 20kHz)
140W+140W (4 ohms, 1kHz)
Output bandwidth (8 ohms, THD 0.03%) 5Hz - 40kHz
THD (20Hz - 20kHz, 8ohms) 0.015%
Cross modulation distortion 0.015%
Frequency characteristic 20Hz-20kHz+0 -0.3 dB
Dumping factor (8ohms) 100
Input sensitivity/impedance Phono man month: 2.5mV/47kohm
Phono M 250 microvolts/100 ohms
Tape, Tuner, Aux, compact-disk:150mV/25kohm
Output load impedance Tape out: 900ohms
RIAA deflection 20Hz-20kHz±0.2dB
SN ratio (IHF-A network) Phono MM:86dB
Phono MC:70dB
Tape, Tuner, Aux, compact disk: 98dB
Phono maximum permissible input MM:140mV
MC:14mV
Tone control property Bass: ±10dB (100Hz)
Treble: ±10dB (10kHz)
Subsonic-Filter property 50Hz
Power source 100V, 50/60Hz
Power consumption 230W
Dimensions Width 416x height 136x depth of 334mm
Weight 10.5kg
http://audio-database.com/MARANTZ/amp/pm-64-e.html
http://media.photobucket.com/image/marantz%20pm%2064/mr-valljud/Samling/Marantzpm-64inside.jpg?o=4
Pret: 500ron
91.83 KB |
83 Time(s) |
Ultima modificare efectuata sloop la Lun Mar 21, 2011 12:32 am, modificat de 11 ori in total |
sloop
sloop
Trimis: Sam Apr 17, 2010 10:08 am Titlul subiectului: up |
Subwoofer auto JL AUDIO 10W0-8 ( Made in USA), Putere 125 w RMS, impendanta 8 ohmi, diametru 25 cm, cutie solida.
Pret nou 180ron din cauza unei mici gauri facute in suspensie de un nepot
Nominal Diameter: 10 inches (250 mm)
Continuous Power Handling: 125 Watts
Voice Coil: 1.38" diameter, 6-layer, Kapton former
Available Configurations: 8 ohm (Single Voice Coil)
Xmax (one-way, linear): 0.34" (8.6 mm)
Sealed Enclosure Range: 0.50-0.90 cu.ft. (14.0-25.5 liters)
Ported Enclosure Range: 0.90-1.50 cu.ft. (25.5-42.5 liters)
VRC Technology: YES
http://mobile.jlaudio.com/pdfs/10_12_15W0_MAN.pdf
http://www.procarsound.com/catalog/product_info.php?manufacturers_id=28&products_id=307&osCsid=0f341...
13 KB |
161 Time(s) |
87.35 KB |
203 Time(s) |
Ultima modificare efectuata sloop la Vin Ian 21, 2011 6:40 pm, modificat de 2 ori in total |
sloop
Trimis: Dum Mai 09, 2010 2:06 pm Titlul subiectului: up |
Amplificator auto Alpine 3566 made in Japan, 6 canale, crossovere.
Pret: 400ron
Channels 1 to 4:
4 x 30W @ 4 ohms (14.4V - 0.08% THD)
4 x 40W @ 2 ohms (14.4V - 0.3% THD)
2 x 80W @ 4 ohms bridged (14.4V - 0.3% THD)
Channels 5 & 6:
2 x 60W @ 4 ohms (14.4V - 0.08% THD)
2 x 80W @ 2 ohms (14.4V - 0.3% THD)
1 x 160W @ 4 ohms bridged (14.4V - 0.3% THD)
Fuse: 2 x 25A
http://www.kaufen-von-privat.de/html/alpine_verstarker.html
http://ampguts.com/gallery/showgallery.php?cat=146
146.1 KB |
139 Time(s) |
70.72 KB |
99 Time(s) |
Ultima modificare efectuata sloop la Vin Noi 05, 2010 12:44 am, modificat de 5 ori in total |
sloop
Trimis: Dum Mai 16, 2010 6:11 pm Titlul subiectului: up |
Amplificator Rotel RA-980BX varf de gama, stare foarte buna ( o zgarietura deasupra care se vede in poze ). A fost desfacut pentru a poza interiorul impecabil. Fara interventii !
Transformator toroidal, 6 tranzistori finali pe canal ( in total 12 ).
http://www.rotel.com/content/manuals/ra980bx_eng.pdf
Pret: 1000ron
95.92 KB |
100 Time(s) |
122.74 KB |
107 Time(s) |
Ultima modificare efectuata sloop la Joi Mar 31, 2011 8:21 am, modificat de 13 ori in total |
sloop
Trimis: Lun Mai 24, 2010 8:51 pm Titlul subiectului: up |
Placa de sunet profesionala pentru laptop ECHO INDIGO IO, 24bit/96Khz, PCMCIA (Card bus Type II). Am placa si cutia, placa e in stare perfecta de functionare.
http://www.soundcreation.ro/placi-de-sunet-pentru-laptop-pcmcia-express-card-cid195_1820/echo-indigo-io-id1368.html
http://www.echoaudio.com/Products/CardBus/IndigoIO/index.php
REVEIW: http://www.stereophile.com/computeraudio/1104echo/index.html
Inregistrarile audio profesionale nu fost niciodata asa de de accesibile inainte de aparitia pe piata a seriei Indigo de la Echo Audio. Indigo IO ofera o intrare si o iesire stereo pe jack de 1/8", pe un card Cardbus tip II, alimentat direct de la laptop.
Convertoarele excelente care functioneaza la 24biti/96kHz ofera calitatea de care ai nevoie, iar cablul de 1.8m inclus in pachet ofera interconectarea pe RCA sau pe jack de 1/4".
O trasatura unica a Indigo I/O este abilitatea sa de a folosi iesiri "virtuale". Interfata este vazuta de catre aplicatii ca si cum ar avea 8 iesiri separate, care sunt mixate digital inspre iesirea fizica folosind consola virtuala de mixaj proprie a Indigo I/O-ului cu ajutorul DSP-ului on-board. Aceasta functie face Indigo I/O compatibila cu toate programele audio cunoscute. Iar cu ajutorul driverelor "multi-client", mai multe aplicatii pot trimite date audio spre iesire in acelasi timp.
Pret: 400ron
Parametri Indigo IO:
Canale I/O ADAT optice: nu
Drivere: WDM, ASIO, GSIF, CoreAudio
Iesire casti: da
Iesiri analogice: 1 x 1/8"
Interfata: PCMCIA
Interfata de control integrat: nu
Intrari analogice: 1 x 1/8"
MIDI I/O: nu
Monitorizare de joasa latenta: da
Nr. canale I/O: 1 / 1
Preamplificare de microfon: nu
Rezolutie maxima: 24biti / 96kHz
S/PDIF: nu
Tensiune fantoma 48V: nu
Wordclock: nu
Alimentare prin interfata: da
48.01 KB |
30 Time(s) |
Ultima modificare efectuata sloop la Joi Apr 07, 2011 9:42 am, modificat de 3 ori in total |
sloop
Trimis: Lun Mai 31, 2010 10:02 am Titlul subiectului: up |
Crossover auto activ SONY XEC-505
Pret: 190ron
http://s6.bilder-hosting.de/img/BF4HO.jpg
Sony XEC 505 - crossover specifications
General
Product Type Crossover
Recommended Use Car
Form Factor Half-DIN - In-dash unit
Width 7.0 in
Depth 4.3 in
Height 1.0 in
Weight 1.3 lbs
Dimensions (WxDxH) / Weight In-dash unit : 7.0 in x 4.3 in x 1.0 in / 1.3 lbs
Enclosure Color Black
Enclosure Material Metal , Plastic
Audio System
Sound output mode Stereo
Audio system controls Rear level , Subwoofer level , Front level
Crossover type 2-way active crossover
Crossover channel qty 6
Crossover slope 12.0 dB/octave
Crossover low pass frequencies 120 Hz , 80 Hz , 180 Hz
Crossover high pass frequencies 80 Hz , 120 Hz , 180 Hz
Crossover bass boost frequency 40 Hz
Radio
Type None
CD System
CD system type None
TV Tuner
Type None
Connections
Connector Type 2.0 x DC power input ( RCA phono ) , 2.0 x Subwoofer output ( RCA phono x 2 ) , Audio line-out ( RCA phono x 2 ) , Audio line-in
108.64 KB |
218 Time(s) |
44.35 KB |
234 Time(s) |
Ultima modificare efectuata sloop la Lun Aug 02, 2010 10:14 am, modificat de 4 ori in total |
sloop
Trimis: Lun Aug 02, 2010 10:13 am Titlul subiectului: up |
Cablu interconect RCA, 1m, nu stiu ce firma e, constructie solida, filtru ferita.
Pret 30ron
59.64 KB |
28 Time(s) |
82.06 KB |
34 Time(s) |
Ultima modificare efectuata sloop la Mie Apr 13, 2011 1:22 pm, modificat de 5 ori in total |
sloop
Trimis: Lun Aug 09, 2010 10:56 am Titlul subiectului: up |
upppppp
_________________ Stereo sounds better than ever... Atoll IN80 + Dual CL730 |
sloop
Trimis: Lun Aug 16, 2010 11:27 am Titlul subiectului: upp |
upp
sloop
Trimis: Lun Aug 30, 2010 11:12 am Titlul subiectului: DIVERSE |
Ultima modificare efectuata sloop la Lun Noi 22, 2010 11:25 am, modificat de 9 ori in total |
