tot_acelasi
Conectat la: 15 Dec 2005 Mesaje: 96 Locatie: Pitesti
Trimis: Lun Mar 08, 2010 8:41 pm Titlul subiectului: EE MINIMAX DAC Tube/SS, Boxe varf de gama DUAL CL 730 |
Eastern Electric MiniMax Dac nou, ambalaj original, factura, garantie 2 ani.
Specifications
Frequency Response : 15Hz – 32KHz
Sampling rates : 32bit 32KHz 44.1KHz 48KHz 192KHz (except USB)
Dynamic Range : 129dB
Digital Input Impedance : 75 ohm
Output Impedance : Tube 22K/Solid State 10K
Output Voltage : Tube 3V +- 0.5dB/Solid State 2.5V +-0.5dB
S/N ratio : Tube 90dB/Solid Sate 95dB
THD : 0.5%(Tube) 0.02%(Solid State)
Power Consumption : 12W
Main Voltage : 120V, 230V, 240V switchable
This DAC uses the ESS 9018 Sabre DAC chip. It has a 12AU7 tube output also which is switchable between the digital output or the tube output.The best of both worlds.Tube or solid state output selectable.
It also has a selectable PHASE IN/OUT button employed.
Inputs are AES/EBU, BNC,RCA,OPTICAL and USB.
Review :
6Moons
http://www.6moons.com/audioreviews/easternelectric/dac.html
Dagogo
http://www.dagogo.com/View-Article.asp?hArticle=798
StereoMojo
http://www.stereomojo.com/Eastern%20Electric%20MiniMax%20DAC%20Review/EasternElectricMiniMaxDACReview.htm
DigitalAudioReview
http://www.digitalaudioreview.net.au/index.php/audio-reviews/digital-source-reviews/item/175-eastern-electric-minimax-tube-dac
Audiophilia
http://www.audiophilia.com/wp/?p=4804
Pretul meu 560 euro (pretul este intre 700 euro in europa si 890 lire in UK).
Cablu interconect Xindak AC-02 nou, ambalaj original, nefolosit.
Pretul meu 135 ron (pretul este 200 ron in magazine).
Cablu Eagle cable digital ofc green, nou ambalaj original, nefolosit. Pret 40 ron.
Dock digital Onkyo nd-s1 black, nou, in ambalajul original, garantie.
Specificatii :
http://www.eu.onkyo.com/products/ND-S1.html
Review
http://www.techradar.com/reviews/audio-visual/hi-fi-and-audio/hi-fi-accessories/onkyo-nd-s1-654012/review
Atentie ! Dock-ul are numai iesire digitala !
Pretul meu 400 ron (pretul in magazin minim 650)
Boxe DUAL CL 730 - varful de gama.
Sunet foarte echilibrat(medii, joase, inalte), neutru, nici rece nici cald. Incinta pe compresie, necesita amplificator puternic, preferabil pe tranzistori. Bas-ul extrem de controlat si definit. Inaltele si mediile pe calota. Au borne si pentru 4 si pentru 8 omi. Comutatoare de reglare a nivelului de joase, medii, inalte cu 2, 4 sau 6 dB.
Difuzoarele si filtrele sunt impecabile, nereparate niciodata. Butonul la unul din comutatoarele de joase are un mic joc dar functioneaza perfect. Una din fete are putin julita panaza la un colt.
Technical data
Design: 3-way closed
Chassis:
Woofer: 1x 245 mm
Midrange: 1 x 50 mm (cap)
Tweeter: 1 x 25 mm (cap)
Handling (Nenn-/Musikb.): 120 / 150 Watt
Efficiency:
Frequency response: 20 - 25,000 Hz
Transition areas:
Impedance: 4 to 8 ohms (separate terminals)
Special Features
Recommended room size: 20 - 60 m²
Thermo-float technique (heat sink within the membrane cone)
Level controls for bass, mid and high
Electronic circuit protection against thermal overload of the tweeter
Pentru cine intereseaza am si revista germana in care au fost testate si declarate cele mai bune boxe la acea vreme ("There is certainly the best that is currently available in this price and volume class.").
Boxele sunt in Bucuresti.
Pret FIX 950 ron.
messenger tot_acelasi - va rog nu dati "add" la user folositi optiunea new conversation si introduceti id-ul meu
telefon 0752175180
Ultima modificare efectuata tot_acelasi la Mie Apr 27, 2011 10:56 am, modificat de 81 ori in total |
Trimis: Lun Mar 08, 2010 8:41 pm Titlul subiectului: Mitica |
125.33 KB |
180 Time(s) |
112.63 KB |
87 Time(s) |
124.95 KB |
93 Time(s) |
tot_acelasi
Trimis: Sam Mar 20, 2010 12:47 am Titlul subiectului: |
preturi negociabile.
tot_acelasi
Trimis: Mar Mar 30, 2010 12:50 pm Titlul subiectului: |
modificari
cablu ecosse 180 ron.
tot_acelasi
Trimis: Mie Apr 07, 2010 9:41 am Titlul subiectului: |
tot_acelasi
Trimis: Lun Apr 19, 2010 4:59 pm Titlul subiectului: |
tot_acelasi
Trimis: Mie Apr 28, 2010 12:55 pm Titlul subiectului: |
tot_acelasi
Trimis: Sam Mai 08, 2010 10:38 am Titlul subiectului: |
tot_acelasi
Trimis: Lun Mai 17, 2010 10:24 am Titlul subiectului: |
negociabil in limita bunului simt
tot_acelasi
Trimis: Mar Mai 25, 2010 3:41 pm Titlul subiectului: |
up !
tot_acelasi
Trimis: Mar Iun 08, 2010 1:12 pm Titlul subiectului: cablu boxe ecosse ES2.3 |
up !
Ultima modificare efectuata de catre tot_acelasi la Mar Iun 15, 2010 8:11 pm, modificat de 1 data in total |
tot_acelasi
Trimis: Mar Iun 15, 2010 2:46 pm Titlul subiectului: Re: cablu boxe ecosse ES2.3 |
reduceri de pret :
cablu boxe 130 ron
Ultima modificare efectuata de catre tot_acelasi la Mar Iul 06, 2010 8:54 am, modificat de 1 data in total |
tot_acelasi
Trimis: Mie Iun 23, 2010 1:19 pm Titlul subiectului: Re: cablu boxe ecosse ES2.3 |
reduceri
tot_acelasi
Trimis: Joi Iul 01, 2010 1:27 pm Titlul subiectului: Re: cablu boxe ecosse ES2.3 |
up !
tot_acelasi
Trimis: Mar Iul 20, 2010 3:50 pm Titlul subiectului: Re: cablu boxe ecosse ES2.3 |
up !
tot_acelasi
Trimis: Dum Aug 01, 2010 11:04 pm Titlul subiectului: Re: cablu boxe ecosse ES2.3 |
up !
