Vand Receiver NAKAMICHI AV7
killer666
Conectat la: 30 Oct 2004
MesajTrimis: Mie Mar 23, 2011 8:18 pm    Titlul subiectului: Vand Receiver NAKAMICHI AV7 Raspunde cu citat (quote)
Receiver AV de inalta fidelitate, de la Nakamichi din punct de vedere calitate a sunetului se bate cu multe statii stereo. Este modelul AV 7. Aparatul este ca nou tehnic si fizic. Sunt primul proprietar,cumparat personal de la master HI-FI(am si factura) nu a fost reparat niciodata, telecomanda,manual,cutie
Analog Audio Section Inputs: 7 (DVD,CD, Aux, Tape, Video, VCR 1, VCR 2) Recording Outputs: 3 (Tape, VCR 1, VCR 2) Output: Subwoofer: 1 Input Sensitivity/Impedance: 150 mV/47 kohms Rated Output Level/Impedance: Recording Output : 150 mV/1 kohm Subwoofer Output : 1 V/1 kohm Total Harmonic Distortion: Less than 0.01% (20 - 20,000 Hz) Frequency Response: 10 - 50,000 Hz +0, -3 dB Signal-to-Noise Ratio: Better than 75 dB (A-WTD, input shorted) Channel Separation: Better than 55 dB (1 kHz, input shorted) Tone Controls Bass/Treble: 20 Hz ± 10 dB / 20 kHz ± 10 dB Loudness: 20 Hz + 10 dB, 20 kHz + 6 dB Video Section Inputs: 4 (DVD, Video, VCR 1, VCR 2), Coaxial Outputs: 3 (VCR 1, VCR 2, Monitor), Coaxial Video Signal Level/Impedance: 1 Vp-p/75 ohms Frequency Response: 5 Hz - 10 MHz +0, -3 dB Surround Section: Surround Mode: 4 (Pro Logic, Natural, Hall, Stadium) Speaker / Subwoofer Mode Settings and Signal Characteristics: Center mode: 3 (normal, wide, phantom) Channel Level Calibration Range Center: -10 to +10 dB Rear L/R: -10 to +10 dB Subwoofer: -10 to +10 dB Delay Time Calibration Range Center: Pro Logic: +15 to +30 ms in 5-ms steps Rear L/R: Natural/Hall/Stadium: +15, +20, +25, +30, +40, +50 ms Power Amplifier Section Continuous Sine Wave Power Output Stereo: 100W x 2 (8 ohms, two channels driven, 20 - 20,000 Hz, 0.1% THD) Surround: Front: 80W x 2 / Center: 80W / Rear: 80W x 2 (8 ohms, five channels driven, 20 - 20,000 Hz, 0.1% THD) Dynamic Output Power: Front: 120W x 2 / Center: 120W / Rear: 120W x 2 (8 ohms, five channels driven) Power Bandwidth: 10 - 40,000 Hz (Half rated power, 0.1% THD) Total Harmonic Distortion: Less than 0.1% (Rated power, 20 - 20,000 Hz) Intermodulation Distortion: Less than 0.1% (Rated Power, 60 Hz: 7 kHz, 4:1) Output Current Capability: 20 A Peak (Per channel, two channels driven) Consuma 950w max
NU prezinta semne de utilizare, de cand il am sta intr-un singur loc, doar ce l-am sters de praf
Accept si unele schimburi cu amplificatoare stereo(acesta este si motivul vanzarii, nu am de mult sistem 5.1 acasa)
Consum de curent max 950wati
Pret 350EURO
Tel 0721 204 915 RObert
Tel:0721.204.915
Vezi profilul utilizatorului Trimite mesaj privat Codul Yahoo Messenger Codul MSN Messenger
MesajTrimis: Mie Mar 23, 2011 8:18 pm    Titlul subiectului: Mitica
 Filesize:  63.21 KB
 Viewed:  96 Time(s)
