pompilius
Conectat la: 26 Dec 2010 Mesaje: 5 Locatie: Calarasi
Trimis: Dum Apr 03, 2011 4:36 pm Titlul subiectului: Vand receiver Onkyo Integra A-SV810PRO |
Este un amplificator foarte bun, din gama Integra.
Nu are absolut nici un fel de problema, arata si functioneaza foarte bine.Toate butoanele si functiile de pe el sunt utilizabile (100%)
Din pacate nu am telecomanda originala.
Pot sa trimit in schimb o telecomanda universala care in afara de programari face cam ce facea si cea originala.
Pret: 600 lei
telefon: 0723836823
- power otput:
by-pass(two channel streo) mode 75W/channel min. RMS at 8 ohms, both channel driven,
from 20Hz to 20.000 Hz, with 0,06% total harmonic distorsion
Dolby pro-logic - 85 W/channel min. RMS at 8 ohms, front L or R channel driven, 1000 Hz with no more
than 0,5% total harmonic distorsion
- total Harmonic Distorsion: 0,06% at rated power
- damping factor 90 at 8 ohm(FRONT)
- sensitivity and impedance phono - 5mV/50kohm
cd, tuner, tape/dat, vdp, dbs,video(play) - 300mV/50kohm
tape/dat video(REC) - 300mV/2,2kohm
preout/subwoofer - 1V/600ohm
- frequency response - 2to 100.000Hz, +/-3dB
- phono RIAA deviation - 20 to 20000 Hz +/-0.8 dB
- tone control bass - +/- 12dB at 20Hz
mid - +/- 12dB at 850Hz
treble - +/- 12dB at 20kHz
- signal to noise ratio phono - 80dB(IHF A, 5mV input)
cd, vdp - 105 dB(IHF A)
VIDEO
- sensitivity and impedance - VDP, DBS, VIDEO 1 - 4(PLAY) VIDEO input: 1Vp-p,75 ohm
VIDEO 1 - 3(REC),MONITOR OUT VIDEO output: 1Vp-p,75 ohm
Dimensions (W x H x D) : 455 x 170 x 421 mm
Weight: 17,5 kg
