sorin6
Trimis: Lun Iun 20, 2005 11:14 am Titlul subiectului: ALte cateva linkuri |
This calculator - two-way first-order Butterworth crossover network http://www.carstereo.com/help/Articles.cfm?id=8
Loud Speakers 101 http://www.carstereo.com/help/Articles.cfm
Two-Way Crossover Network Design http://www.carstereo.com/help/Articles.cfm?id=3
Multi-Way Crossover Design http://www.trueaudio.com/st_xov_1.htm
Two-way cross-over basics. What IS a crossover? http://www.mmxpress.com/technical/twoway.htm
Balanced vs Unbalanced, Passive vs Active http://www.bssound.com.au/advice/bsadvice.htm
Building your own 2nd order passive Crossover network http://www.colomar.com/Shavano/crossover12db.html
The Subwoofer DIY Page v1.1 Subwoofer Integration http://www.diysubwoofers.org/misc/sub_integration.htm
RME level adjustment +4/-10 dBu and servo balanced inputs and outputs http://www.rme-audio.com/english/aeb/index.htm
Matt's DIY audio page http://kahuna.sdsu.edu/~tucker/diyaudio/diyaudio.html
X-overs and Bi-amping http://kahuna.sdsu.edu/%7Etucker/di.../ramblings.html
24db/octave Linkwitz-Riley http://kahuna.sdsu.edu/%7Etucker/diyaudio/xover.html
Active Crossovers for DIY Speaker Builders http://www.snippets.org/filters/crossover.htm
THIEL SmartSub Controller - "Do I need a crossover?" http://www.thielaudio.com/THIEL_Web..._needxover.html
The HS500. The most powerful plate subwoofer amp available to the DIYer today http://www.adireaudio.com/diy_audio...fiers/hs500.htm
Integrating A Subwoofer With Your HiFi http://www.audioetc.tv/articles/int...ferwithhifi.htm
Subwoofers for Music - EXCELLENT http://www.soundstage.com/maxdb/maxdb200101.htm
Google search - subwoofer low frequency cut-off filters (e.g. 16Hz...) http://www.google.com/search?hl=en&...cut-off+filters
Why is it so difficult for subwoofers to blend into a system? http://www.vandersteen.com/pages/Answr9.htm
The Marriage Between the Subwoofer and Tower Speakers http://www.audioholics.com/techtips...ofer_towers.php
ACI Subwoofer Primer http://www.audioc.com/information/subwoo.htm
It is common knowledge that crossovers contribute to coloration http://www.merlinmusic.com/reviews/hfr_495.htm
SPEAKER PASSIVE CROSSOVER ASCENSION http://www.jensencapacitors.com/aud...es/artikel.html
"crossoverless" speakers http://www.onhifi.com/askwes/ask0014.htm
Removal of the crossover eliminates phase & group delay distortion http://www.brentworth.com/
and delivers a musical performance that has every nuance preserved
Why horns http://www.hornspeakers.info/
Adire Audio - Maelstrom http://www.adireaudio.com/diy_audio...e/maelstrom.htm
Neutralizing L(e) with a Zobel Network http://www.trueaudio.com/st_zobel.htm
Subsonic Filters are high-pass crossovers centered around 25-30Hz http://www.rockfordfosgate.com/scri....php?p_faqid=68
subwoofer subsonic filters - Google search http://www.google.com/search?hl=en&...ubsonic+filters
SVS Amp Interface by Marchand Electronics http://www.svsubwoofers.com/marchandsubsonic.htm
No need for subsonic filtering - sealed design http://www.danmarx.org/audioinnovation/theories.html
Sealed Subwoofers http://www.acc.umu.se/~sagge/audio/1259/
Sealed Speaker Enclosure Design Calculator http://www.loudspeakers101.com/SealQtc.htm
How The Linkwitz Transform Circuit Works - and qtc .707 sealed subwoofer http://sound.westhost.com/linkwitz-transform.htm
Therefore a hipass or "subsonic" filter, even for sealed boxes, could help reduce distortion http://www.diysubwoofers.org/projects/cartf/
Sealed Box Subwoofer http://home.insightbb.com/~stephenw...x_Subwoofer.htm
Marchand WM8 "BASSIS" Bass Correction Equalizer http://www.marchandelec.com/wm8.htm
The sealed system provides the best group delay numbers http://www.adireaudio.com/tech_papers/sub_gd.htm
Phase, Time and Distortion in Loudspeakers http://sound.westhost.com/ptd.htm
speaker sub enclosures http://www.madisound.com/
REL Strata III Subwoofer review - let mains run full! http://www.21stcenturyservices.com/audio/REL_Strat3.htm
The Perfect Subwoofer http://www.21stcenturyservices.com/audio/perf_sub.htm
Extended Low Frequency or ELF - mains run full... (active sub) http://sound.westhost.com/project48.htm
Thiele - Small Analysis of Loudspeaker Enclosures http://www.silcom.com/~aludwig/Sysd...ll_analysis.htm
250W SUBWOOFER AMPLIFIER w/REMOTE CONTROL http://www.partsexpress.com/pe/psho...r=300-793&DID=7
subwoofer Class D - Class AB amplifier http://www.xcs.no/index.php?artikkelid=67&back=1
KGND-52100 Powered Subwoofer Amplifier Class D 1000 Watts @ 4 Ohms http://www.madisound.com/kgnd.html
Velodyne SPL-800 Class D subwoofer amp review http://www.audioholics.com/productr...eSPL800-p3.html
subwoofer in and out of phase, phase reversing - Google search http://www.google.com/search?hl=en&...G=Google+Search
Audioreview - subwoofers http://www.audioreview.com/Subwoofers/PLS_2741crx.aspx
Welcome to Madisound Speaker Components! http://www.madisound.com/
The Subwoofer DIY Page v1.1 Definitions http://www.diysubwoofers.org/misc/dumax/dumax.htm
Updated NOUSAINE subwoofer data list http://www.avsforum.com/avs-vb/show...hlight=nousaine
Updated NOUSAINE subwoofer data list http://members.cox.net/frankcarter/...0Sub%20Data.htm
True Balanced outputs http://www.avsforum.com/avs-vb/show...threadid=301971
subwoofer calibration system - software http://www.etfacoustic.com/
Adire Maelstrom Speakers Review by Pland http://www.audioasylum.com/audio/sp...ages/97841.html
THE ANCIENT AUDIOPHILE'S QUEST FOR THE ULTIMATE HOME SYSTEM http://invalid.ed.unit.no/~dunker/ultimate.html
ð Speakers Frequency Response http://www.pispeakers.com/PiGraph.htm
Multiple Subs http://www.avsforum.com/avs-vb/show...threadid=298137
Biamplification basics - an article http://www.audioasylum.com/audio/ge...ages/57210.html
DIY speaker building information http://home.earthlink.net/~etunstal/diy.htm
DIY Loudspeaker Designer's Selection Guide (the LDSG) http://ldsg.snippets.org/index.php3
Section 7 - Recommended drivers http://ldsg.snippets.org/sect-7.php3
Recommended drivers technical specifications http://ldsg.snippets.org/sect-12.php3
Appendix A - Loudspeaker Design http://ldsg.snippets.org/appdx-a.php3
LDSG Appendix A - Enclosure designs http://ldsg.snippets.org/boxes.php3#SEALED
Section 17 - Suppliers of prefabricated enclosures http://ldsg.snippets.org/sect-17.php3
Section 16 - Recommended louspeaker kits and plans http://ldsg.snippets.org/sect-16.php3
Speakerbuilding.com http://www.speakerbuilding.com/content/1014/page_5.php
Home Audio DIY Speaker FAQ http://www.lalena.com/audio/faq/speaker/
Details of the VR-6 and VR-8 Technology http://www.vonschweikert.com/vrline/VR-6W.HTM
JPO Speakerbuilding Linklist http://members.chello.se/jpo/
Try downloading a program like WinISD Pro alpha http://www.linearteam.dk/
Welcome To DIYSPEAKERS.NET http://www.diyspeakers.net/
spherical cermaic speakers - least distortion http://www.zako.com/techrev.htm
How to Design a Sealed Loudspeaker? - Qts, Fs sealed speaker enclosure... http://gecko.gc.maricopa.edu/~jmurb...udio/sealed.htm
Thiele-Small Terms and Definitions or just "T/S Parameters" http://www.mmxpress.com/technical/terms.htm
Zobel Networks, speaker design http://www.adireaudio.com/tech_papers/tech_central.htm
Speaker design calculator http://www.mhsoft.nl/spk_calc.asp
Neutralizing L(e) with a Zobel http://www.trueaudio.com/st_zobel.htm
Initial Enclosure and Crossover Designs - Zobel network http://www.angelfire.com/electronic.../modelling.html
Passive Crossover Basics - Zobel Networks http://www.eatel.net/~amptech/elecdisc/xoorder.htm
Crossover Design http://www.silcom.com/~aludwig/Sysd...sove_Design.htm
Sample 3 Way Crossover http://www.lalena.com/audio/faq/xover/
DIY audio homepage http://www.lalena.com/audio/
The Loudspeaker Design Cookbook - $39.95 http://www.amazon.com/exec/obidos/t...891827?v=glance
Part II: Digital Filters* http://www.silcom.com/~aludwig/Sign...tal_filters.htm
Design of the Sound System http://www.silcom.com/~aludwig/Sysd...ound_system.htm
Construction of the Loudspeakers http://www.silcom.com/~aludwig/Loud...#Time_alignment
DIY'ers perspective on the top-selling Bose system http://www.intellexual.net/bose.html
Design of Loudspeakers http://www.linkwitzlab.com/design_of_loudspeakers.htm
Crossovers - 1st order http://www.linkwitzlab.com/crossovers.htm
F - Group delay and transient response http://www.linkwitzlab.com/frontiers.htm#H
JBL horns, speakers http://www.usspeaker.com/
Impedance Equalization Designer Help - Zobel Networks http://www.lalena.com/audio/calcula...qual/help.shtml
3-way 1st order crossover is used in a 3-way vented enclosure system http://www.kbapps.com/audio/speaker.../xover3way.html
Slop Of The Crossover - tweeter/1st order @ 2kHz NO GOOD... http://www.caraudiogalaxy.com/carau...opcrossover.htm
ScanSpeak tweeters - Google search http://www.google.com/search?hl=en&...nSpeak+tweeters
tweeter 1st order crossover - Google search http://www.google.com/search?hl=en&...order+crossover
Time aligned, Phase coherent, Phase aligned, http://www.geocities.com/kreskovs/TimeAligned2.html
Transient accurate, What's up with that.
Appendix E - Passive Crossover Components http://ldsg.snippets.org/appdx-e.php3
Crossover Demos http://www.silcom.com/~aludwig/Crossover_demos.html
Topic: 3 way 1st order crossover http://www.electrical-contractor.ne...TML/000006.html
Transient Perfect 2nd Order Crossover http://www.geocities.com/kreskovs/CrossoverdocN.html
3-Way Series Cross-Over http://users.tpg.com.au/users/gradd...ross-overs8.htm
3-way 1st order crossover - Google search http://www.google.com/search?hl=en&...order+crossover
cascading 1st order slopes http://www.mindspring.com/~chucksaudio/eqptrept.htm
Linkwitz-Riley Active Crossovers up to 8th-Order: An Overview http://www.rane.com/note119.html
Very High Quality DIY speakers anywhere? http://www.avsforum.com/avs-vb/show...threadid=170942
A full 300W into 4 Ohms, this CLASS D unit runs very cool http://www.adireaudio.com/diy_audio...fiers/dt300.htm
DIY parts, tech site http://www.partsexpress.com/
Understanding and Designing Passive and Active Crossovers http://www.termpro.com/articles/xover.html
Designing Passive Crossovers http://www.termpro.com/articles/xover2.html
Crossover Component Selection Guide http://www.partsexpress.com/resources/xover.html
A Different Approach to Series Networks http://www.geocities.com/jonrisch/LBIseries.htm
L-Pad Designer Help http://www.lalena.com/audio/calculator/lpad/help.shtml
Impedance Equalization Designer Help http://www.lalena.com/audio/calcula...qual/help.shtml
Inductors, Capacitors, & Resistors http://www.lalena.com/audio/electronics/rcl/
chart of the frequency range of various instruments http://www.silcom.com/~aludwig/Sysdes/Musicsp.gif
Music and The Human Ear http://www.silcom.com/~aludwig/EARS...ve_vs_objective
Fostex Speaker Components - mid-hi drivers http://www.fostex.com/index2.asp?fi...ange/full_range
Fostex Speaker Components - mid-hi drivers http://www.madisound.com/fostex.html
Thiel CS7.2 Specifications 4-way system http://www.thielaudio.com/THIEL_Web/Pages/cs7_2.html
Sealed box - resonance hump (Zobel Networks) http://www.speakerworkshop.com/SW/P...closure%20A.htm
Filters, Zobel Network calculator........... http://users.telenet.be/educypedia/...atorsfilter.htm
The Naked Truth about Speaker-Cables http://www.tnt-audio.com/clinica/spkcbl_e.html
The Naked Truth about Interconnect Cables http://www.tnt-audio.com/clinica/intere.html
Series Notch Filter Designer Help http://www.lalena.com/audio/calcula...otch/help.shtml
Passive Radiator Enclosures: In Theory and In Practice http://momentum.soundillusions.net/august02/tech2.html
RLC circuits match transmission lines to loads http://www.e-insite.net/ednmag/arch...097/08di_05.htm
How well do Zobel circuits stabilize the impedence of a driver? http://www.geocities.com/vyque/Caraudio/passives3
Driver Attenuation Circuit - L-Pad http://www.loudspeakers101.com/Lpad.htm
Loudspeakers 101 main page http://www.loudspeakers101.com/Sound.htm
Maximum Power (Resonance) in Series RLC Circuits http://www3.ltu.edu/~s_schneider/ph...resonance.shtml
Solen printed circuit boards - Lpad http://www.solen.ca/pcb2way.htm
"predicted" impedance http://www.lonesaguaro.com/speakers...alImpedance.gif
L-PADS - calculator!!!!!!!!!!! http://www.eatel.net/~amptech/elecdisc/lpad.htm
Series crossovers, how do they work? And parallel circuits http://home.hetnet.nl/~geenius/Crossover.html
Simplest is best! 1st order, 6dB/octave slope http://members.myactv.net/~je245/spktips.htm
SoundEasy V8.00 has been released - $249.95 http://www.audioxpress.com/bksprods/sotware/sof-sou.htm
First Order (6db/octave) Two-Way Crossover calculator http://ccs.exl.info/calc_cr.html
Unibox software - Design Your Own Loudspeaker Cabinet http://www.danbbs.dk/~ko/ubtxt.htm
Unibox software - Design Your Own Loudspeaker Cabinet http://www.danbbs.dk/~ko/ubdwnld.htm
Series vs. Parallel Wiring http://www.termpro.com/articles/spkrz.html
FRD Consortium is group of designers, experts, hobbyists and programmers http://www.pvconsultants.com/audio/frdgroup.htm
FM (Filter Maker) is a utility for creating Digital Filter Transfer Functions http://www.pvconsultants.com/audio/dsp/dplay.htm
Plotting a Speaker's Impedance: http://www.eatel.net/~amptech/elecdisc/resvsimp.htm
LMS - Loudspeaker Measurement System - $1395 http://www.linearx.com/products/ana.../LMS/LMS_01.htm
Passive Crossover Basics http://www.eatel.net/~amptech/elecdisc/xoorder.htm
speaker crossover design software - GOOGLE search http://www.google.com/search?hl=en&...design+software
plotting speaker's impedance - GOOGLE search http://www.google.com/search?hl=en&...r%27s+Impedance
loudspeaker simulation software - GOOGLE search http://www.google.com/search?hl=en&...G=Google+Search
The gold standard in analog/digital simulation - Micro-Cap 7 http://www.spectrum-soft.com/demo.shtm
True Audio - Welcome to the Loudspeaker Design Center! http://www.trueaudio.com/win_abt1.htm
Loudspeaker Design Tutorial cont.: Page 3 http://www.trueaudio.com/about_3.ht...nce%20Response_
About WinSpeakerz http://www.trueaudio.com/win_abt1.htm
Tech topics http://www.trueaudio.com/st_index.htm
True Audio's WinSpeakerz Design Software review +book review!!!!! http://www.hometheaterhifi.com/volu...october-99.html
TrueRTA does not have gating (below 300-500Hz measurements) http://home.new.rr.com/zaph/audio/audio-speaker11.html
Input and output sampling rates are adjustable up to 48kHz http://www.soniccontrol.com/news/fe...trueaudio.shtml
Also, Oscilloscope for Windows http://polly.phys.msu.su/~zeld/oscill.html
Techron TEF-20 analyzer - acoustic measurements http://www.speakerbuilding.com/content/1014/page_8.php
A summary of recommended speaker design software packages http://ldsg.snippets.org/appdx-c.php3
SOUNDEASY v. 8.00 JUST RELEASED http://www.audioxpress.com/bksprods/sotware/sof-sou.htm
Version 8.00 New Features and Improvements http://www.audioxpress.com/resource...ofsouimprov.htm
SoundEasy V8.00 has been released http://www.e-speakers.com/
SoundEasy V8.00 has been released - about the programs http://www.interdomain.net.au/~bodzio/
SoundEasy V8.00 has been released - about the programs http://www.interdomain.net.au/%7ebodzio/
SoundEasy V8.00 - import from PC-based measurement systems http://www.interdomain.net.au/~bodzio/
SoundEasy (which I use to model things like non-linear distortion, etc.) http://www.speakerbuilder.net/web_f...cts/DBP/dbp.htm
SoundEasy - Yahoo users e-group http://groups.yahoo.com/group/SoundEasyuserslist/
EasyLab - Advanced is an expanded section of SoundEasy http://www.interdomain.net.au/~bodzio/
Small-signal parameter of the Dayton 295-300 woofer http://www.speakerbuilder.net/web_f...cts/DBP/dbp.htm
small signal and large signal analysis http://www.ht-audio.com/e-topic9.htm
difference between small signal model and large signal model? http://www.elektroda.pl/eboard/topic56704.html
LSP CAD - justMLS PC-based measurement system http://home.earthlink.net/~etunstal/diy.htm
LspCAD is short for Loudspeaker Computer Aided Design http://www.ijdata.com/intro.html
LspCAD official site http://www.ijdata.com/
using JustMLS and LSPCad http://www.lonesaguaro.com/speakers/Topaz/Topaz.htm
using JustMLS and LSPCad - excellent measurements tutorial http://www.geocities.com/kreskovs/John1.html
Girardin mic Liberty Instruments http://www.libinst.com/us_domestic_pricing.htm
DIY Speaker Testing Microphone Preamp - Take 2 http://www.gti.net/wallin/audio/preamp2/preamp2.html
True Audio TrueRTA - How might I use a Real Time Audio Analyzer? http://www.trueaudio.com/rta_faq1.htm
Panasonic microphone caplets http://www.panasonic.com/industrial...nts/rec_mic.htm
A DIY Speaker Testing Microphone http://www.speakerbuilder.net/web_f.../diymicmain.htm
MIC-01 and MIC-02 are low cost precision condenser electret microphones http://www.e-speakers.com/products/clio.html
CLIO MIC-01 - $233.80 Lite - or our own Mitey Mike II http://www.audioxpress.com/bksprods/kits/kc-cliom.htm
"all in one measurement jig" http://www.ijdata.com/justMLSjigCharlesRydel.pdf
audio measurement supplies http://www.audioxpress.com/bksprods/kitsindex.htm
OMP/MF Mono Power Amp Modules from BK Electronics http://www.audioxpress.com/bksprods/kits/km-14a.htm
Power Amp Modules ILP Direct Ltd, UK http://www.audioxpress.com/bksprods/kits/ki-hy2000.htm
Developing a DIY speaker inspired by the Wilson Audio X1 SLAMM http://www.cliowin.com/FOTO/gpphoto/Hancock/slamm.htm
Linkwitz - Panasonic omni-directional back electret microphone cartridge http://www.linkwitzlab.com/sys_test.htm#Mic
Loudspeaker Systems Using CALSOD 3.10 http://www.sonicdesign.se/calsinfo.html
Comparison of calculated and measured SPL curve [in half-space]
of a Vifa P17WJ-00-08 woofer http://www.geocities.com/f4ier/xoversimFAQ.htm
"Calibrating" your Radio Shack SPL meter http://www.speakerworkshop.com/foru...topic.php?t=610
QuickMix - setting the audio mixer on your Windows computer http://www.msaxon.com/quickmix/index.htm
Speaker Workshop Project Main http://www.speakerworkshop.com/SW/Project/Main.htm
How to use Speaker Workshop from Audua http://www.gti.net/wallin/audio/audua/audua.html
Speaker Workshop by Audua web site http://www.speakerworkshop.com/
JIG II and Speaker Workshop http://www.gti.net/wallin/audio/SW/SW.html
CLIOwin home page http://www.cliowin.com/index.htm
CLIOWin Lite Electroacoustic Measurement System http://www.audioxpress.com/bksprods/kits/kc-cliom.htm
Acoustic links - MANY!!!!!!!!!!!!!!!!!!!! http://groups.yahoo.com/group/acous...e_001014290697/
Measurement Systems http://members.aol.com/nameaudio/links/measure.htm
Liberty Audiosuite
frequency response of the tweeter measured on a LAud setup http://www.io.com/~patman/s2.html
North Creek Music Systems - DIY matched drivers http://www.northcreekmusic.com/LoudspeakerProjects.html
SpectraPLUS 2.32 SpectraPRO 3.32 SpectraLAB 4.32 - home page http://www.cetaceanresearch.com/analysis.html
HobbyBox German home page http://www.audio-software.de/hobbybox_v_5_mls.html
LspLab home - English home http://hem1.passagen.se/johnygre/ENG/index.htm
LspLab home - $400 with mic http://hem1.passagen.se/johnygre/ENG/index.htm
Sample Champion is an accurate and easy to use audio measurement software http://www.purebits.com/scoverview.html
Sample Champion Application notes - Impulse and Frequency Response http://www.purebits.com/appnotes.html
Impedance measurement and Thiele-Small parameters computation http://www.purebits.com/appnote16.html
Impedance measurement: pratical construction of the connector http://www.purebits.com/appnote17.html
Speaker Measurement Jig - chose Sample Champion http://www.raymondaudio.nl/projects...9/project9.html
PC Sound Card Page http://www.epanorama.net/links/pc/sound.html
The Subwoofer DIY Page v1.1 Measurements http://www.diysubwoofers.org/measure.htm
How do i measure the TS parameters of a misc driver? http://www.diysubwoofers.org/cgi-bi...p&msg_num=34170
Acoustic Measurement Software http://www.me-au.com/measure.html
ETF3.0 is a software application designed to aid in the tuning of sound systems http://www.me-au.com/etf.htm
SPL calculations http://www.adireaudio.com/tech_papers/spl.htm
How many components? Well, the crossover.... http://www.adireaudio.com/tech_pape..._crossovers.htm
Software for Speaker Design http://melhuish.org/audio/software.htm
Driver manufacturers http://www.speakerbuilding.com/drivers/
"close tolerances with their actual/advertised Thiel/Small parameters" - NOT!!! http://www.ellisaudio.com/technology.htm
FAQ: Frequently Asked Questions about Praxis http://www.libinst.com/praxfaq.htm
So, what does the AudPod do? http://www.libinst.com/praxfaq.htm#t7
Liberty Instruments home page - Praxis, AudPod system http://www.libinst.com/
Re: T/S parameters - Praxis http://www.libinst.com/_disc2/00000033.htm
Praxis forum http://groups.yahoo.com/group/laudu...01?viscount=100
Golden Ratio speaker design http://www.cs.northwestern.edu/~pdi...ns/designs.html
Irrational numbers and cabinet design http://www.soton.ac.uk/~apm3/diyaudio/Irrational.html
Spherical Speakers http://www.oddnoise.com/spheres.html
Cabasse iO spherical satellite system http://www.cabasse.com/english/io/
Gallo spherical speakers http://www.anthonygallo.co.uk/productindex.html
Spherical speaker design http://www.zako.com/techrev.htm
Zako ZM99 bowling ball ceramic spherical speakers review - 3 stars http://www.hifichoice.co.uk/review_print.asp?ID=1652
TRIO Classic perfectly reflects the dynamics of the spherical horns http://www.gtaudio.com/speakers.html
Avantgarde Acoustic Uno Series Two loudspeaker: Robert Deutsch review http://www.stereophile.com/showarchives.cgi?287:11
stuffing/damping material lowers Q, Fs - same as increasing enclosure volume http://www.wmeckle.com/1259/1259.htm
stuffing/damping material lowers Q, Fs - same as increasing enclosure volume http://www.danmarx.org/audioinnovation/theories.html
A Hell of a Show - spherical speakers "with balls" http://www.soundstage.com/audiohell/audiohell200302.htm
Spherical piezoelectric ceramic speaker http://www.murata.com/news/1996/0423e.html
Artistic Audio Möbius - ball perched atop a shiny, fork-shaped tuning stand http://www.smr-home-theatre.org/ces...image_008.shtml
Artistic Audio Möbius - ball perched atop a shiny, fork-shaped tuning stand http://www.artisticaudio.com/mobius.asp
Odyssey Setup & Tweak Tips http://odysseyaudio.com/setup_tweak.html
Audio links page, DIY... http://joemacjr.home.att.net/diyproject/links.html
speaker drivers - Seas, Vifa... http://www.linkwitzlab.com/orion_challenge.htm
VonSchweikert Audio VR 2 Speakers Review by ka7niq http://www.audioasylum.com/audio/sp...ges/132286.html
Modifying the Vifa tweeter - resonance chamber stuffing, resonance Fs drops http://www.io.com/~dylan/speakers/vifas.html
Robin Marshall: A Modicum of Genius - tweeters, resonance, low Q... http://www.stereophile.com/showarchives.cgi?567:3
2.1 Driver Evaluation in Closed Boxes http://www.trueaudio.com/about_2.htm
Tempest application notes - Bessel .577, Butterworth .707 Qtc http://www.adireaudio.com/Files/Sea...pplications.PDF
FRD Consortium - frequency response data & tools http://www.pvconsultants.com/audio/frdgroup.htm
Section 1 - Driver guidelines http://ldsg.snippets.org/sect-1.php3
Linear Team - WinIsd 4.x Beta & Alpha Pro - driver database http://www.linearteam.dk/default.aspx?pageid=winisdpro
WAV-Normalizer - not that good - Maximizes volume level in multible wav-files http://www.linearteam.dk/default.as...d=wavnormalizer
Drivers are listed in alphabetical order http://melhuish.org/audio/drivers.htm
UNDERSTANDING LOUDSPEAKER DATA http://www.eminence.com/eminence/pa...ms02/params.htm
Klipsch RF-7 specifications http://www.reliableaudiovideo.com/kliprf7newmo1.html
Klipsch RF-7 specifications http://www.klipsch.com/product/product.aspx?cid=362
Klipsch RF-7 reviews http://www.audioreview.com/PRD_129356_1594crx.aspx
Recommended horn tweeters summary: http://ldsg.snippets.org/sect-10.php3
"How to eliminate low frequency noise cancellation with proper woofer placement." http://www.audiovisualdevices.com.a...vey/woofer.html
How crucial is the localization near the floor? http://www.speakerbuilding.com/content/1039/page_2.php
The Oris Horn Page http://www.welbornelabs.com/oris.htm
The horn speaker home page http://invalid.ed.unit.no/~dunker/horns.html
Specs for JBL drivers http://invalid.ed.unit.no/~dunker/jblspecs.html
The Ambiophonic method is applicable to two-channel sources http://www.ambiophonics.org/
Capacitors in Crossover Network http://www.audioasylum.com/forums/h...ages/57036.html
The Maya Horn System, Oris horns... http://www.moondogaudio.com/products.htm
Modification of a Klipsch horn (bass) http://www.speakerbuilding.com/content/1032/
Meridian DSP6000 digital amp built in! http://www.avguide.com/product/Main...DSP6000/220.jsp
Tetra Realism™ loudspeaker - Acoustic Reality http://www.acoustic-reality.com/Tetra/text3.htm
The Whomp - it achieves a -3db point of 27hz (-10db @ 20hz) http://www.selahaudio.com/whomp.html
Rear-Loaded (Bass) Horns http://melhuish.org/audio/enclosurehornrear.htm
Basic Horn Theory http://melhuish.org/audio/horn.htm
Avantgarde USA home page http://www.avantgardeusa.com/
Avantgarde's bass systems - Subwoofer SUB225 CTRL PRO http://www.avantgardeusa.com/bass.html
Avantgarde DUO Description http://www.avantgardeusa.com/duo.html
ORIS systems around the world http://www.bd-design.com/en-gb/pg_12.html
BD-Design driver manual for Oris horns http://www.bd-design.com/
Horn foldings (many many designs for BASS HORNS) http://www-user.uni-bremen.de/~carn.../hornfolds.html
Accuton C² 44/8 midrange driver http://www.speakercity.com/accuton/C2%2044.shtml
German supermen shatter the laws of physics... again! (bass horns) http://db.audioasylum.com/cgi/m.pl?...orn&r=&session=
Madisound discussion forum http://www.madisound.com/cgi-bin/discuss.cgi
Ultimate tweeters http://ldsg.snippets.org/vendors/scan-spk.php3
Horns (or why I use horns) http://ldsg.snippets.org/HORNS/horns.html
Solid state amps and horns DON'T MIX! http://www.aloha-audio.com/library/Tube_Fest_Talk2.html
RE Designs LNPA-150 monoblock transistor amplifiers http://www.redesignsaudio.com/LNPA150.html
RE Designs LNPA-150 monoblock transistor amplifiers http://www.aloha-audio.com/library/Tube_Fest_Talk2.html
Monarchy SE-100 delux Mono Power Amplifiers $2,358/pr http://www.monarchyaudio.com/SE100-5.htm
Compression driver and horn/lens assembly guidelines: http://ldsg.snippets.org/sect-6.php3#EMINENCE-C
The Ariel - By Lynn Olson A Brief Note about Efficiency http://www.audiokit.it/ITAENG/KitDi.../ArielEffic.htm
The Ariel History By Lynn Olson http://www.audiokit.it/ITAENG/KitDi...rielHistory.htm
Do it Yourself Tube Audio - A Glowing Hobby - subwoofer for Ariel http://www.teresaudio.com/haven/
Adire HE10.1 Kosala Speakers Review by Gene H http://www.audioasylum.com/audio/sp...ges/109656.html
Horns and High-Efficiency Systems, speaker types...!!! http://www.aloha-audio.com/library/speaker-design1.html
Audio Asylum - search page http://db.audioasylum.com/
Symetrix SymNet™ Audio Matrix is a family of network linkable audio matrix DSP processors http://www.symetrixaudio.com/SymNet_Web/index.htm
HOME THEATER has a new SUBWOOFER LEVIATHON!!!!! Must read! http://www.avsforum.com/avs-vb/show...highlight=Bdeap
In Reply to: lab12 vs SHIVA on basshorn - Bdeap bass horns http://www.audioasylum.com/forums/H...ages/55423.html
Tumult driver, Bdeap sub..... http://www.avsforum.com/avs-vb/show...eap#post2746806
Gallo Acoustics Due, MPS Speaker System http://www.audiorevolution.com/equip/gallo/
B&W subwoofer - shape http://www.bwspeakers.com/index.cfm...67F00D0B7473B37
Loudspeaker driver database http://www.thielesmall.com/
Pjay's Speaker building page - driver database http://members.aol.com/_ht_a/pjay99...peakerhome.html
High sensitivity tweeters http://www.madisound.com/cgi-bin/di...cgi?read=272585
AKG Hearo 999 - headphone amp - center channel effects http://headphone.com/layout.php?top...ctID=0010120999
Headphone site http://www.head-fi.org/
Headphone site http://headphone.com/layout.php?topicID=1
Headphone software http://www.akg.com/products/powersl...anguage,EN.html
Speakers - woofer facing up http://www.blackdahlia.com/samadhi/cbae.htm
World's Most Expensive Hi-Fi System?!! http://www.avsforum.com/avs-vb/show...threadid=295441
Crown K2 class D digital amps - subwoofer
Loudspeaker Technology - cubes, spheres, standing waves.................. http://www.norh.com/about/tech/
B-Deap, Servodrive subwoofer http://www.servodrive.com/SPL-bdeap32.html
Balanced vs. Unbalanced Cables http://www.wpi.edu/Academics/Depts/.../bal-unbal.html
Impedance, damping factor myth, balanced vs. unbalanced connections... http://sound.westhost.com/impedanc.htm
DENOMINATIONS ABOVE ONE MILLION - American & British systems http://www.webster.com/mw/table/number.htm
Series vs. Parallel Crossover Networks http://sound.westhost.com/parallel-series.htm#1.3
Audiophile Capacitors http://sound.westhost.com/cables-p5...le%20Capacitors
Speaker design books and reviews http://www.amazon.com/exec/obidos/A...2699345-1453419
Class A amplifiers http://sound.westhost.com/class-a.htm
B&W Nautilus 801 loudspeaker outdoor listening test http://www.tnt-audio.com/casse/bw801e.html
Gershman Acoustics Avant Garde RX-20 reviews http://www.audioreview.com/PRD_119559_1594crx.aspx
Mirage Loudspeakers http://www.miragespeakers.com/omnipolar_tech.shtml
JBL Studio Monitors http://www.proaudiosystems.co.uk/ac...nitors_162.html
StealthBoxz - sub enclosure, standing waves... (car sub) http://www.auto-acoustics.co.uk/faq3.htm
Google search - subwoofer internal standing waves http://www.google.com/search?hl=en&...+standing+waves
axial, tangential and oblique standing waves http://www.coincidentspeaker.com/about.htm
Rane PE-17 Five Band Parametric Equalizer - for subwoofer (balanced only) http://www.svsubwoofers.com/ampeq_rane_pe17.htm
Center channel speaker(s) http://www.avsforum.com/avs-vb/show...047#post1230047
Near field surround system http://www.mkprofessional.com/pdf/mps-422.pdf
Comb filtering effect http://www.asc-hifi.com/acoustic_basics.htm#2
Speakers around TV set - uggghhh... http://www.mkprofessional.com/pdf/mps-422.pdf
spherical and egg shaped loudspeaker enclosures http://www.usenclosure.com/cst-oem.htm
Wiremold power strip http://www.naimusa.com/power.html
Behringer (sp?) DSP 1124 is a great piece of equipment to eq a sub http://www.avsforum.com/avs-vb/show...threadid=312010
Tannoy - 3-way nearfield monitors with nearfield elliptical cabinet http://www.pro-music-news.com/html/10/e20401ta.htm
JBL S36II - molded enclosure with Elliptical Oblate Spheroidal waveguide http://www.onecall.com/PID_15014.htm
JBL S312II - specifications... http://www.onecall.com/PID_15090.htm
Baffle diffraction http://www.t-linespeakers.org/tech/...step/index.html
Loudspeaker Diffraction Loss and Compensation http://www.trueaudio.com/st_diff1.htm
Diffraction from baffle edges http://www.linkwitzlab.com/diffraction.htm
Diffraction is a difficult subject........... http://www.linkwitzlab.com/faq.htm#Q8
AudioPrism Noise Sniffer http://www.audioprism.com/noisesniffer.html
Cabinet shape http://www.ellisaudio.com/CabinetShape.htm
Behringer Feedback Destroyer - setup http://www.snapbug.ws/bfd.htm
optimize low frequency acoustic response of rooms through trial and error measurements http://www.etfacoustic.com/demoroom.all.html
Baffle Diffraction Simulator is a design program and education tool http://www.pvconsultants.com/audio/...downloadbds.htm
Understanding Cabinet Edge Diffraction http://www.speakerdesign.net/understand.html
an ideal baffle is very large http://audio.sdecnet.com/diy_reflector/
Magneplanar speakers http://www.magnepan.com/
Magnepan MG20.1 vs. B&W Nautilus 801 http://www.epinions.com/content_2418516100
baffle diffraction compensation http://www.ameritech.net/users/kagato/xover1.htm
baffle diffraction compensation - Google http://www.google.com/search?hl=en&...G=Google+Search
Baffle Diffraction Theories and Practice http://www.t-linespeakers.org/tech/...bstepcompo.html
Spherical diffraction compensation http://yu-ra.tripod.com/baffle_diff.htm
crossover - with baffle diffraction loss compensation (CALSOD) http://www.geocities.com/capecanave...3/flrspkrs.html
Baffle diffraction loss http://yu-ra.tripod.com/index_general.htm
infinite baffle measurements, speakers... http://home.new.rr.com/zaph/audio/audio-speaker13.html
Diffraction - From Wikipedia, the free encyclopedia http://en.wikipedia.org/wiki/Diffraction
The Thiele-Small Loudspeaker Database - works w/Unibox http://www.thielesmall.com/
The "6dB Response Step", and infinite baffle uniformity... http://www.northcreekmusic.com/NorthCreekKits.html
baffle diffraction compensation - DIY contest http://www.kaiaudio.com/diy2001/kaiopen.html
Baffle Step Equalisation http://sound.westhost.com/bafflestep.htm
Speaker dust cap http://web.mit.edu/2.972/www/report...er/speaker.html
THIEL floor-standing speakers employ a rounded baffle http://www.thielaudio.com/THIEL_Web...iffraction.html
http://www.thielaudio.com/THIEL_Web...qtimephase.html[/url]
The Acoustic Benefits of Phase Alignment http://www.wescomponents.com/SSS/se...rs_in_a_rec.htm
The Acoustic Benefits of Phase Alignment http://www.wescomponents.com/sss/ac...phase_align.htm
Time aligned, Phase coherent, Phase aligned, Transient accurate, What's up with that? http://www.geocities.com/kreskovs/TimeAligned1.html
Time aligned, Phase coherent, Phase aligned, Transient accurate, What's up with that? http://www.geocities.com/kreskovs/TimeAligned2.html
Time aligned, Phase coherent, Phase aligned.... GLOSSARY http://www.geocities.com/kreskovs/TimeAligned1.html
Time-alignment measurements http://www.silcom.com/~aludwig/Time_alignment.html
Veneering Recessed Driver Cutouts http://www.audiodiycentral.com/nt_drvrcutouts.shtml
Time- and phase-correct performance - 1st order crossovers..... http://www.soundstage.com/video/rev...een_theater.htm
Baffle spacing, phase angles and time alignment, revisited http://www.audioasylum.com/forums/p...ages/11054.html
spreadsheet for offet drivers/crossovers and phase correction... http://www.d-web.com/dbrown/db61ta/phase.xls
For starters, scrambling the waveform is JUST PLAIN WRONG! http://www.meadowlarkaudio.com/TC4.htm
Speakers with vertical baffles are NOT time coherent ! http://www.meadowlarkaudio.com/TC1.htm#1
Illustration: flat baffle, slanted baffle and point source phase responses http://www.meadowlarkaudio.com/TC1p.htm
Subject: Baffle spacing, time alignment and driver offset http://www.diysubwoofers.org/talksh...sages/33527.htm
Crossover transient response http://www.silcom.com/~aludwig/Sysd...nsient_response
ALIGNED DRIVERS? http://members.chello.se/jpo/papers/align/ALIGN.html
drivers time align - GOOGLE SEARCH http://www.google.com/search?hl=en&...vers+time+align
Subwoofer damping material http://www.diysubwoofers.org/sld/sealed4.htm
The Following is a Discussion on Stuffing a Sealed Enclosure http://www.wmeckle.com/1259/1259.htm
Acousta-stuf @ Parts Express (& damping materials) http://www.partsexpress.com/webpage...ectGroup_ID=137
HyperSonic Sound - focused sound waves http://www.atcsd.com/tl_hss.html
damping baffle panels - with 'Router Pad' http://www.snippets.org/alsr/const.html
Making felt front baffle diffraction pads http://t-3.cc/users/audioworx/page90DIY-FeltPads.html
Felt Rings verses Felt Blocks for Baffle Diffraction Reduction http://www.speakerdesign.net/felt/f..._vs_blocks.html
Reduce front baffle loudspeaker diffraction losses - tweaks http://www.audiotweaks.com/tweaks/tweak_284.htm
Measuring Loudspeakers, Part Three http://www.stereophile.com/showarchives.cgi?103:0
Give it a Tilt! (Tilt your speakers backwards for a new experience!) http://www.echoloft.com/articles/aug2000/tilt.htm
Measuring driver volume - Vs, Vb... http://sound.westhost.com/tsp.htm
driver displacement volume http://www.google.com/search?hl=en&...lacement+volume
driver displacement volume http://www.trueaudio.com/win_abt1.htm
The WinSpeakerz Box Calculators http://www.trueaudio.com/about_4.htm
Avantgarde Trio installations http://www.avantgardeusa.com/installations.html
Room Acoustics http://www.silcom.com/~aludwig/Room...orrible_optimum
Subwoofer room gain..... http://www.ellisaudio.com/subwoofers.htm
Unibox - Design Your Own Loudspeaker Cabinet http://www.danbbs.dk/~ko/ubtxt.htm
1.0 Introducing The Speaker Design Toolbox http://www.trueaudio.com/about_1.ht...g%20WinSpeakerz
Correction Values for Radio Shack SPL Meter http://www.danmarx.org/audioinnovation/rsmeter.html
Rane PE17 Five Band Parametric Equalizer http://www.svsubwoofers.com/ampeq_rane_pe17.htm
parallel & series battery wiring schematics http://www.solarexpert.com/Batteries/batchart.html
SOS - Subwoofer Optimizer System $299.95 each http://www.speakercity.com/Sos/SubwooferOptimizer.shtml
How do you eq your sub? http://www.avsforum.com/avs-vb/show...20&pagenumber=1
Behringer DEQ2496 Ultra-Curve Pro Mastering Processor (subwoofer) http://www.musiciansfriend.com/srs7...tp?q=ultracurve
Open Baffle Line Array Speakers http://www.geocities.com/dmitrynizh/labaffles.htm
Dipoles/open baffle - Is the "figure-of-eight" radiation better than the "conventional" radiation? http://www.roister.com/eng/faqs.htm
Room acoustics - By far the most uniform response in the range below 200 Hz http://www.linkwitzlab.com/rooms.htm
is obtained with an open-baffle, dipole or figure-of-eight radiating source
The Subwoofer DIY Page v1.1 Dipole Bass Systems http://www.diysubwoofers.org/dipole/
The Contrapunt, a dipole sub woofer. http://www.euronet.nl/users/temagm/audio/dipolesub.htm
Dipole Bass - Adire Audio DPL-12 drivers http://sho.mystarband.net/BBContent/BBBass.html
2 350 Watt plate amps from Stryke Audio http://stryke.com/amplifiers.html
A Word About Enclosure Filler (sealed subwoofer) http://www.bullysubs.com/design_phil.html
Meyer Sound HD-1 : High Definition Audio Monitor http://www.meyersound.com/products/.../hd-1/index.htm
ELAC Technische Software CARA 2.0 computer program http://www.stereophile.com/showarchives.cgi?438
RPG Diffusor Systems Room Optimizer http://www.rpginc.com/products/roomoptimizer/
RPG Diffusor Systems - CATT-Acoustic v8.0 http://www.catt.se/
RPG® developed the Shape Optimizer http://www.rpginc.com/products/chaos/index.htm
ETF software is a highly accurate PC based acoustic measurement system http://www.acoustisoft.com/
CARA 2.1 PLUS (includes CARA Training CD) http://www.rhintek.com/
CARA - official site http://www.cara.de/ENU/index.html
Updated CHECK OUT the NEW CARA 2.2 http://www.reflexlabs.com/
About Acoustics http://www.reflexlabs.com/page728281.htm
ELAC Technische Software CARA 2.0 computer program review http://www.stereophile.com/showarchives.cgi?438:0
CARA Walkthrough http://www.cara.de/ENU/CARA/index.php?load=box3.html
RPG Room Optimizer http://www.sweetwater.com/store/detail/RoomOptimizer/
The Sound of Quality in Monolithic Domes http://www.monolithic.com/plan_design/sound/index.html
Bouncing Off the Walls Controlling acoustics in a Monolithic Dome http://www.monolithic.com/plan_desi...tics/index.html
Audio Systems Enhance Living Word Bible Church http://www.monolithic.com/gallery/c...word/index.html
Test Results Of Acoustics In Monolithic Dome Gyms Delight The Tester http://www.monolithic.com/plan_design/gym_acoustics/
EASE 4.0 - Enhanced Acoustic Simulator for Engineers - $1995 http://www.falconaudiovideo.com/
EASE 4.0 - Enhanced Acoustic Simulator for Engineers http://www.olsonsound.com/EASE/articles.html
EASE 4.0 - Enhanced Acoustic Simulator for Engineers - developer site http://www.auralisation.de/index.html
EASE 4.0 - Takes Off The Limits http://www.ada-acousticdesign.de/ea...bout_ease40.htm
ODEON Room Acoustics Modelling Software (dome?) http://www.bksv.com/?ID=2154
Room Acoustics & Sound System Design Links http://www.audioscientific.com/Room...ign%20Links.htm
JBL Professional software downloads http://www.jblpro.com/pages/software_downloads.htm
room nodes, bass cancellation, EQ... http://www.futuremusic.co.uk/fm_mmu...D=6809&PageNo=5
Golden Ratio room setup http://www.audiolinks.nl/speakersetup.htm
Carvin's SX series solid-state guitar amps - John Murphy on tube amps http://www.trueaudio.com/at_eetjlm.htm
WinSpeakerZ "complete" offer, user guide, book, software... http://www.trueaudio.com/catalog1.htm
BassBox Pro - SPHERICAL ENCLOSURES! http://www.ht-audio.com/bassbox.htm
Room interaction - reflections, absorbtion, reverb time, etc http://www.diysubwoofers.org/talksh...sages/34343.htm
Diffraction-Free Sound Waves http://www.aip.org/physnews/graphics/html/yusuke.html
ODEON Room Acoustics Modelling Software - expensive http://helmholtz.oersted.dtu.dk/~odeon//
ODEON Room Acoustics Modelling Software - expensive http://www.bksv.com/?ID=2154
EASE V3.0 http://www.jblpro.com/pages/software/software.htm
Preserving Wanted Sound, room acoustics.... - excellent! http://www.usg.com/Design_Solutions..._preserving.asp
Speak 2.5 - official site - $299.95 http://www.gedlee.com/speak.htm
room acoustics - curved surfaces http://www.google.com/search?hl=en&...curved+surfaces
Room Acoustics - Design For Listening (curved surfaces...) http://irc.nrc-cnrc.gc.ca/cbd/cbd092e.html
Software links http://members.optusnet.com.au/~audiosoft/sahfsd07.txt
Room acoustics (curved surfaces...) http://www.linkwitzlab.com/rooms.htm |
